Hi all
I have a used 3" Kakimoto R cat back exhaust that came off my R34 GTT.
It will fit all R34 GTT coupes. ie. lines up with the stock cat.
For all other skylines, should require a little modding to fit.
It is quiet, has a nice deep tone, and no drone. This is a quality system from Kakimoto.
This is in excellent condition, comes up nice and shiny as you can see.
If you are sick of your cannon, or tired of your loud/cheap exhaust note, this will be a good replacement.
$400
In Sydney. Please PM for further details.
Cheers
Edited by nuffsaid
PIcs added
And link to exhaust on Kakimoto website:
http://www.kakimotoracing.co.jp/01-02-02_K...02-02_KR01.html
JASMA approved and < 92dB, fair to say you wont get hassled by the boys in blue for this exhaust.
Edited by nuffsaid
Ive always wanted a Fujitsubo.
Can I ask what you expect to get out of a Fujitsubo over this one? I understand you're also not a fan of cannon's or noisy mufflers. I mean, do you expect it to be quieter, look better or something else? Surely it'll cost you a lot for no real tangible gains in power or performance?
The reason I'm asking as I'm also a fan of the Fujitsubo Legalis R. I'm currently looking at a custom build with a Magnaflow muffler cat back, but am worried I won't get the right look or it might be too noisy (or even performance!)... what was your experience?
i have had the exact same exhuast on my car cat back kakimoto system for the past 2 1/2 years. (i have a full 3"system but the catback part is kakimoto) good exhuast very quiet for 3" system with 2 mufflers. i have since had the middle muffler taken out of the system and a straight pipe welded in, sounds a bit more grumbly now, but if u are after a good exhuast with minimal noise this is the one. it was designed by kakaimoto to keep the DB below the legal limit.
GL with the sale free bump. :D
Edited by 85URK
It can as its simply a sticker. It is stuck on pretty hard, but I am sure a heat gun or something would be able to get it off. Polish it and itll look like it never had a sticker.
I think its nicer with that sticker there though.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
