Hi,
I have an r33 gts-t with a hks gt2835 pro s and all supporting hardward, run by an apexi power fc
at the moment im making
320rwhp @ 12psi
and
337.7rwhp @ 16psi
now i am happy with my tune but not happy with the overall hp figure, ive done a search and found other people are making much more power with the same power and same mods.
my question will be is, im running a custom fmic and piping
now i know for a fact my piping has been cut and rewelded to fix my car, and the overall design of the piping looks average, also im using a china cooler. could this be casuing a flow issue and therefore giving me a lower power?
also i have a feeling that one section of the piping, may not be complete smooth on the inside possible causing turbulent flow
-michael
https://www.sau.com.au/forums/topic/132787-weakest-link/
To see if the cooler is the problem.
Just measure the pressure before the I/C and then after it.
If there is a drop, then you have a problem :P
Would this have to be done on the dyno? and im guessing my tuner should have the tools to measure this?
thanks for the reply
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2459745
id be interested to see the IGN and INJ maps
also afr on the dyno plot would have been helpful
is it possible to get a print out from my tuner of the IGN and INJ maps ? i have been meaning to get a printout with the afr, i may do that this week if it will help find out wat the possible problem could be
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2459780
' date='3 Sep 2006, 11:29 PM' post='2459745']
Yep, they should be able to do it without to much of a drama
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2459795
hmm,
im getting abit worried about my result
the other day my mate how has a s2 r33 with a highflow turbo got 240kw @ 16/17psi and he had issues with the turbo itself (needs to be reported or something)
this is something like 10hp less than me :S and im pretty sure the 2835 is bigger than a highflow
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2469438
Also,
i've been thinking about the issue with my I/C piping and Cheap Cooler.
the friction lose in the pipe itself could be causing an increase in the TOTAL HEAD, resulting in a drop in overall pressure. How great would the pressure drop need to be to affect power?
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2469441
well i think it goes that if you are running 10psi and the guage and actuator read from the compressor outlet or before the intercooler and intercooler core causes a 3psi pressure drop then there will be 7psi pressure in the manifold past the intercooler, which means less "boost".
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2469447
thanks for that info paul,
i think im going to have to look into this issue more, as i can see its the only issue why my power figure is lower
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2469459
Was it the same mixturs at both boost levels?, I doubt it is the intercooler and piping, it would have to be pretty bad to lose that sort of power, i would be looking at the ign table, you could do a run on 12psi on the street, datalog the load cells, then do one at 16psi,look at how much timing has been removed to allow for the extra boost, should only be about 4deg, you can measure pressure drop in the intercooler system with a boost gauge, hook it up to the manifold and see how high it goes, then connect it to the compressor housing, should only see 1 psi difference. oh and its a bit rich, 12.2 should be fine for that power level.
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2475555
There's nothing too wrong with the power you are making considering the boost run and the a/f ratio. I'm assuming stock cams?
Get cams, watch as the car spits out another 25-30rwkw at the same boost and should just scrape 300rwkw with a bit more boost.
Ive seen a stock cammed rb25 with 2835proS make 269rwkw with more boost and a bottle of octane booster, but the same car is only making 256 on 16psi and pump fuel. It also uses a china intercooler.
https://www.sau.com.au/forums/topic/132787-weakest-link/#findComment-2475622
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
