  • Replies 45
Posted Images
$1k for the whole car is an absolute joke, eng and g/box alone are worth at least $3k.
I do not know this seller, just dislike it when other people try to take advantage of someone when they are volnerable :P.
theres not alot available of the car .. i dont know why he didnt detail that earlier. It was misleading not to show the car as it sits now.
This guy is a mate of a mate of mine..
I will get on to him a get the owner to do a list of what would be available..
And please DONT take advantage of this guys bad luck. (1000 4 the lot) what the..
Cheers.
im wrecking whole car so tell me what u want and i also have a set of plates 4 sale UNIQ33
what is the part numbe for the drivers side power window button, and how much if its the right one?
sorry guys had some personal matter 2 take care off, will post all parts availible tuesday
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
