I have a few r33 series 1 parts as I bought a complete car that was a write-off for its driveline
Off the top of my head I have: very rough prices listed...
carpet $50
roof lining $40
rear lights in black $100
standard boot with spoiler in black good condition $150
boot carpet $40
aftermarket exhaust HKS super dragger (cat back) $250
complete rear end with diff - 120 000ks $600
front struts $100
rear windscreen $50
rear quarter glass both sides $80
all parts are still in car
may be selling complete brake setup with the right offer
All items pick up from South Sydney or North Sydney only
PM with offers
Edited by steigs
https://www.sau.com.au/forums/topic/133104-fs-r33-series-1-parts/
  • 4 weeks later...
please post pics of the exhuast as im interested, if its in good condition im ready to buy
could post them to my email addy: jrdn @ bigpond (dot) net (dot) au
Edited by gts-4 dreamer
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
