Ok, looks like we're almost done. I will be posting up pics this weekend. Using the string + glue + metal wire really turns it from being just a seat cover into a retrim.
Jeez, my gf's parents must either love me or hate me by now, i've lived there for 3 weeks now.
  • Replies 129
Posted Images
I dunno about everyone else, but I can't make heads or tails of all the posts and different ways people have put their seats on.
JetDat is there any chance of getting some set of instructions or similar from UAT?
Cheers.
Im not sure if its me but the seat not look like they are flat..
what about the curves from the seat???
i guess seat covers are different from an actual interior shop...
but let me know if im wrong.. cause by looking at the Pics the curves are gone...
also just want to know when you sit into the seat does the actual material sink in? cause it dosent look like it stuck the the seat aswell..
Ozan and I put in an effort yesterday arvo and now the passenger seat is in my car - it looks unreal. Shouldn't take more than about 20 minutes per seat for my drivers & both his fronts.
Plan what you're doing, use the strings - crochet hooks are your friend.
Will post pics when done, probably next weekend.
there is a possibility i mite organise another group buy as i have friends who want some at the group buy prices...
but its a bit of work and i dont have the time lately...but i will see what i can do...
ok i just got a quote from a trimmer to rip out the cloth interior, add a bit more padding on the seats and install the covers + door trim + fix the centre console cover for $400.
car is r34 gtt and will be doing it on the 2nd week of october.
will post pix on how it will go.
Nice jonjon, I've found the seats are quite comfy and padded enough, but each to their own! Ozan & I will probably get a professional trimmer to do the door inners and parcel shelf.
Does anyone know of decent car upholsterers etc in Brisbane?
A couple of more pics
Hey Eddie, nice seats.
What colour is your car? Is it the stock silver?
I was trying to figure out what colour would be good for a silver car.
You wouldn't have a faraway pic of your car that shows the seats, do you?
After a mammoth effort, Ozan and my seats are done (pending a few little cleanup steps & replacing back seats).
They look the goods, I will upload some pics of work in progress & the completed product.
Depending how much I'm feeling like a perfectionist, I think I may redo the rear seat-back (the far driver's side strings) as they could line up a little nicer, but in general very happy with how it all went.
My niggle is that the embossing on the rear driver's side is imperfect, probably an inch or so offset so looks askew.
Final stage will involve the door trimmings and parcel shelf, and whatever else I think of if sufficient scrap material remains.
Cheers to Jetdat for organising the buy and Ozan for providing the workshop & extra set of hands where required.
I just want to say thanks to Arman (jetdat) for the awsome group buy.
I had a little trouble with one of my covers and he sorted it all out for me and its getting sent over now!
Tops to you Arman!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
