I used to run the adjustable Whiteline swaybar. A friend has a turbo conversion in his R32 GTS so gavce his my old swaybars to usem inlcuding the links.
Only now when i open the kit to install the new swaybars, they arent complete with all the bits needed, and actually use some of the old/std parts / links etc.
So can someone post up pics of the undersides of their cars so i can try and suss out the bits i need to buy?
https://www.sau.com.au/forums/topic/133413-swaybar-help/
From a Whiteline stabiliser bar fitting kit perspective;
The front bars, adj and fixed, both use the standard D brackets
The fixed bar uses the standard drop links
The adj bar uses special links (Whiteline supply them with the bar)
The rear bars, adj and fixed, both use the standard D brackets
The fixed rear bar uses the standard drop links
The adj rear bar uses special links (Whiteline supply them with the bar)
Let me know what you need, I have a few sets of links (no D brackets though) on the shelf for emergencies.
:D cheers :(
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2472911
It seems i need the D-brackets, and im not sure i have all the bushes needed to install the swaybars themselves? Need photos as its been 6 nmonths since i took off my old bars... photos would be good.
I may just get the wheel alignment ppl to sort it all out??? Id rather do it myself though as the expense of doing this rally that im gettign the car ready for is out of control :laugh:
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2473680
I may just get the wheel alignment ppl to sort it all out??? Id rather do it myself though as the expense of doing this rally that im gettign the car ready for is out of control :(
Roy,
You should have two D brackets/bushes per bar. The photo is of the GT-R bars, but the droppers are much of a muchness. Gt-R set only comes with the rear droppers - the fronts just bolt up to the standard ones.
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2473982
Theres the ticket then, my fronts didnt come with any bushes. And the D brackets need a fiar bit of tweaking to fit the bush. After a lot of cursing i still want able to do them alst night. One hr sleep in over 2.5 days and i ran out of puff...ph and forgot to put wheels back on the car when dropping it off the jack.... oops ;) Very tired :P
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2487605
Well just rang Whiteline to order them and they are telling me the adjustable front swaybars use std links. Looking at the car that has my old swaybars they are aftermarket links and definitely not std. So something has chamged as Whiteline since i had my original ones fitted.
The adventures of doign things to crs when you have a deadline...time to try Noltec i think.
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2488614
Standard links on R33's and R34's, but Whiteline links on R32's. You want me to send you a link kit, I have a couple of spare sets? PM will do.
:huh: cheers :blush:
PS; I don't have any spare D bushes or D brackets though.
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2489348
My adjustable front bar didn't come with links for my r32. :3some:
Standard one seems to work alright, just need to to get off my arse one of these days and replace the rubber bush with some poly ones i have lying around
https://www.sau.com.au/forums/topic/133413-swaybar-help/#findComment-2490240
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
