Don't let that put you off. A lot of the cars there definetly aren't up to show standards. The front of mine is riddled with stonechips and I still put it in last year, and it got a good reaction too :O
Lol yeah my front bar hasnt been painted but Im still gonna go! represent the poor P plater who has no money :O
  • Replies 67
Posted Images
Don't let that put you off. A lot of the cars there definetly aren't up to show standards. The front of mine is riddled with stonechips and I still put it in last year, and it got a good reaction too :wub:
hehe yeah but your car still looks good & you don't see that many nice R31's around like yours...
crappy stock series1 R33's however...
especially when i still have to fix some minor damage, I'm sooo slack >_<
ok, so forgive me for being paranoid but...to what extent is this going to be a catalog for the more dodgy members of the public? hint hint
Any car show is a catalogue for more dodgy members of the public. Though last year no one caught my eye as suss or anything like that.
Realistically speaking your car is on show everytime you take it out of the garage so it's much of a muchness really I suppose, but that's just the way I look at it
  • 1 month later...
I took mine there with a small ding in the back door last year and the front end riddled with stonechips. And I'd do it again this year :D
No matter how imperfect your car may seem there's always going to be some other one there on the day which makes yours look like it's just come off the showroom floor
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
