apparently it fouls your plugs pretty quickly?
dont quote me on that however.
why do you use octane booster? is your car tuned for a higher RON?
I agree mitchy, I can remember seeing a test done on TV and the only thing the octane boost did was boost the cash outer your wallet.
gun-r32, I would jsut stick to the good ol' BP 98... in a years time think of the $$$ you will have saved on the octane boost and you can buy me a pressy for the tip! :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479088
even if it is tuned for higher octane, may aswell just get it tuned for 98ron or something more commonly available.
the money you save on octane booster will allow you to buy more mods to make up the slight loss in power from lower octane. :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479192
the money you save on octane booster will allow you to buy more mods to make up the slight loss in power from lower octane. :)
Ahhhh.... wise words from a wise man. :D
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479199
the car was only tuned on ultimate 98 + some octane booster to reduce pinging. I was advised that I should try to use some octane booster every fill, more as a safeguard than anything. Might try a few fills without and see if the knock level increases at all.
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2479394
i bought a bottle of wynns or sumthin octane booster the other day, havnt used it yet cos i hardly put more than 20 bux of fuel in at a time, most probably wont get to use it as aswell, lol, the person at the shop said every 6 months put a bottle in just to get the stuff through the system lol i just bought it cos i was bored :down:
https://www.sau.com.au/forums/topic/133661-octane-booster/#findComment-2481747
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
