Hey it would be much appreciated if someone could check the details on this stagea....
Cheers,
Tom
Vehicle
Identification
Year1996VIN7A8DH610707004660MakeNissanChassisWGC34-004660ModelStagea 25XColourGreen
Engine
Assembly
NumberRB25-6703217Country of originJapanCapacity2,498 ccAssembledOutside New ZealandPowerNot enteredVehicle typePassenger car/vanFuel typePetrolBody styleStation wagonAlternative fuelNot enteredNumber of seats5
Weight
Axles
Gross1,745 KgTypeNot enteredTareNot enteredNumber2
Wheel baseNot entered
  • 4 weeks later...
Please Please Please :rofl: I'll pay for the beer!
Decode this:
VIN Chassis # BNR34-005129
MODEL# GGJPRWYR34ZDAAAK-D
$5.00 Paypal to the first one who decodes her! :domokun:
Thank you very much!!!
I really do need this done... any help would be much appreciated!
Regards,
Turbodaddy
  • 3 months later...
Hi There
Can you please help. I am looking a buying a R32 GTR V Spec, It looks like I have found one. It has all the V Spec options, but i would like to confirm.
Here are the VIN Details
Chassis # BNR32-302103
Model # KBNR32RBFS AA
KH2 G
FS5R30A RC 41
I spoke to Nissan, they couldn't confirm it was a V Spec. They did say it was not a normal GTR it is a GTR.17 special model
Thanks
  • 1 month later...
  • 2 months later...
  • 1 month later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
