I got these Results :
HCR32-009253 - June 1989
HNR32-001731 - October 1989
HCR32-027344 - September 1989
HNR32-005374 - March 1990
Yep!
Our results both match up!
Lol that's so odd - I might double check it tomorrow morning... :(
Let us know how you go!
Yep!
Got it all sorted - i was losing the last number when copying and pasting the vins and FAST would automatically just add a 0 to the vin number lol... silly me!
:laugh:
Well there you go!
Can I please have somebody check that this VIN is a legitimate V-Spec II NUR
BNR34- 403495
Thank you
If this source is correct, I think you have found a V-Spec II Nur or M-Spec Nur...
Spec Codes as follows:
BRAK6 = Big Rear Brake
CLAS2 = V-Spec II Nur / M-Spec Nur
COAT3 = Super Fine Hard Coating
COLD2 = Cold Region Package
CVRR2 = Advanced Aero System
GLSSW = Privacy Glass
LMRF2 = Rear Fog Lamps
METS2 = Multi Display Meter
NAVI3 = Navigation +6 Speakers
WIPR2 = Rear Wiper
Can you confirm this with the car?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
