Hi everyone. Im saved up a bit of cash and want to mak the 33 go that little bit harder. I have recently read here that ppl dont advise running more than about 12 psi on the stock turbo (i currently have the boost set to 10) If i wanted to raise boost levels to say 15-16psi is it better just to hiflow the stock turbo as opposed to buying a new one which seems like the much more expensve alternative. How do ppl rate hiflows?
https://www.sau.com.au/forums/topic/133745-to-hiflow-or-not-to-hiflow/
Have you installed an ecu?
With a highflow, you will need an aftermarket ecu, then fuel pump, then injectors to get the full potential.
Buy an ecu first, this unlocks sooooo much hidden potential within the std motor/turbo.
I have a hi-flo and new ecu...basically get urself something like a PFC first. also look at the zorst, AFM etc before u bother i guess. few post aboutt what to do first.
yeah ok cool. i already got exhaust and cooler and was gonna get the power fc now with the turbo. How r u finding the hiflow? is it noticibly lagier?
i would definately recommend the hiflow option. good power increase over stock. i got a vg30 single turbo exhaust housing adapted to mine for abit more top end :down: result being 346hp(258kw) at wheels on 15psi. u make up your own mind !!
so on stock r33 ecu you have 346rwhp ?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
