Would be good if that was a pic of a turbo
Yeah its a hydro something... I used to know... back when jesus was in the yearbook this pic was new and I could of told you.
From memory its a hydro something... used for water pumping or some crap, its not a turbo :)
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2482706
I wonder what K&N would charge for a pod filter for one of those bad boys, if they actually were turbo's.
An engine that size wouldnt exactly be spinning at enogh revs to spool a turbo, id think...
Well this T88-34D is pretty big, and its on the floor of my room... not hanging off a power station... pumping water...
haha and for $2500 it could be on the floor of YOUR room!!
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2491403
hmm i suppose thered be a shite-load of momentum in a turbo that size at 600rpm. Would need a half-hour turbo timer. but i guess it wouldnt get that hot.
Is it actually a turbo? as in, driven by exhaust fumes? or is it just a motor-driven pump... Looks like just teh compressor, no impellor
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2491545
Doesent get hot at all as its a water turbine (Hydro). Water enters the valve on the left and spins the impellor inside which is connected to a generator via a shaft. Generator creates the 3000 kw. It uses variable vane technology like the new porsche turbso to regulate the flow of water and different head pressures to maintain the 600rpm rotation speed.
When the valve is turned off and the water stopped it takes the impellor around 20 minutes before it stops spinning if the hydraulic brakes aint used.
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2491573
so... hydro-electricity, then.... a turbine, that spins a big magnet with a shit load of copper cable around it...
20 min... i was close. i gues. give or take 10 min.
Still after the biggest TURBO, then!!
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2491582
All those earlier ones that pump water or whatever...i reckon they still qualify.
Just cause the pump water instead of air doesn't mean the aint turbines.
Turbos are just small turbines anyway.
that being said....i wanna find a pic of the one on a diesel powered cruise ship!
https://www.sau.com.au/forums/topic/133746-big-turbo-post/#findComment-2491988
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
