have u had any problems with the cyclops alarm interfering with the car the way it idles, sometimes stalls or wont go past 2400 revs
no. in all of the installs I haev done with that unit it only kills the ign circuit. IN NO WAY was it tied to any sensor. now if you have an idling problem I would be looking for codes on the computer. I would also have a spare airflow sensor handy. that sound more like your problem than the alarm.
food for thuoght- if you have had a shot at teh fitter for this problem - apologise pls.
actually i have one with a built in turbo timer. theres a seperate button to turn off the car too if you think its running too long. i do notice when the car is idling and i arm the alarm it sounds like the car drops in revs slightly but notably. also i have had the car/alarm 5 weeks now and twice it failed to disarm!! i ended up looking like a car thief wandering around for 5 mins pressing the clicker until it decided to disarm. so far so good...but for how long...???
I do not usde the turbo software on those. placement of the module affects teh remote though. I usuall extand the antenna on them. the one I have on my car has never faulted.
I have one on my 4dr.
No problem at all.
I have just had a Greddy FATT fitted last week. It does drop in revs just while the car arms itself then goes back to normal idle range.
Besides that there is no problem with my alarm at all.
Yeh as the guy above said. I hope u didnt have a crack at the installer. And if it was his fault ppl make mistakes.
But good luck with it all anyway mate.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
