I'm inserting this post around motoring forums to alert interested road users, particularly those in the NT.
Whilst I personally support the introduction of a rural default speed restriction for NT, it must be made 'quite clear' to MP's, that the adopted rural default NOT be applied on roads to which a speed derestriction sign is posted.
This means NT can then have BOTH a 'rural default speed restriction' AND 'speed derestriction allowance' as it applies right now, but only to a specific length of road, that is, where it is posted.
The speed derestriction sign (//) is an international road traffic sign, it's meaning in the UN Convention on Road Traffic, Road Signs and Signals "END OF ALL LOCAL PROHIBITIONS IMPOSED ON MOVING VEHICLES", hardly 'default speed limit', or 'speed limit 90, 100, 110km/h'.
SHOULD NT residents wish to retain the speed derestriction allowance, I SERIOUSLY advise you to CONTACT your local MP, see links below:
Let them know if you support a rural default or not, BUT ALSO - let them know to KEEP the speed derestriction sign, should a rural default arrive, so it can then be used on NT''s safest lengths of road.
MAKE THE EFFORT, or lose forever your right to drive 'safely' - unhindered, at speeds above 100km/h.
THE THREAT:
http://www.abc.net.au/stateline/nt/content/2006/s1736723.htm
NT COUNTRY LIBERAL PARTY:
http://notes.nt.gov.au/lant/members/Member...&Expand=1#1
NT TERRITORY LABOUR
http://notes.nt.gov.au/lant/members/Member...&Expand=3#3
NT INDEPENDENT:
http://notes.nt.gov.au/lant/members/Member...&Expand=2#2
  • 3 weeks later...
NT members of parliament vote on a 110km/h maximum speed limit this week.
If you don't wish this to happen, you *must* now ring and make contact with your local MP and tell them how *you* want them to vote at the time.
Edited by Keepleft
Cant see a speed limit of 110 happening. Very dangerous for a government to try and bring this in, going to be very hard to Police too. I would suggest that they will put a speed limit of around 140 and police it fairly loosely.
there isnt enough cops in the nt to try and police that lol
id still get on it,
everyone in the NT, anyone that has ever used these roads, should contact their MP,
dont let em do it.
a losing battle i would think ,,, its only a matter of time before this is implemented Australiawide...
Dont Worry about Policing it ..I am sure you will be introduced to the elustious Seniour Cunstable camera....
end of an era which is sad ....
  • 4 weeks later...
NT's speed derestriction is no more.
NT's NEW maximum rural default speed limit is 110km/h.
Some key NT highways are to have signposted 130km/h speed limits.
Other changes are a demerit points system based on the national model, and increased fine levels for speed and other offences.
http://www.saferoaduse.nt.gov.au/changesataglance.html
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
