FS: Jaycar Response AMP 4 Channel
Guest crackity
Hi Guys,
My amp i ordered from Webaudiodirect over a fricken month ago has finally arrived. I had contacted them several times as it was only meant to take 5 days to get to me, and they never replied. So i bought a new amp, and what do you know? they send this out 4-5 weeks late and charge me for it. They wont credit me back either.
So here it is. I no longer need this amp. It is unopened, 1 day old - never touched still in the box they sent it in.
the specs are below. im asking what i paid, $398.99. Keep in mind this has literally never even been wired up before.
I will not ever recommend webaudiodirect again. If they replied to me and said "sorry this will take a couple of weeks" it would have been ok. But they blatantly ignored my polite requests.
thanks guys.
Response AA0435 4 Channel Amplifier
This amplifier will give 100WRMS x 4 channels into 8 ohm, or 150WRMS x 4 into 2 ohms, or with the channels bridged 300WRMS x 2 into 4 ohms, at distortion of 0.05%. Other features include variable input sensitivity 0.25 to 2.5 volts, variable crossover on both front and rear channels from 40 - 120Hz at 12dB/oct, high and low pass switchable. Bass boost front and rear, variable 40 to 120Hz at 0 to +18dB variable. High quality gold plated power and loudspeaker connections, power 4 gauge, speakers 8 gauge, easily accessable blade fuses.
- Ideal for our double magnet subs.
Specifications:
- Power/channel @ 4 ohms 100WRMS x 4
- Power/channel @ 2 ohms 150WRMS x 4
- Power/channel bridged @ 4 ohms 300WRMS x 2
https://www.sau.com.au/forums/topic/13393-fs-jaycar-response-amp-4-channel/
  • 7 months later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
