  • Replies 69
Friday's no good for me as I've got a work BBQ, so it's tonight, or the weekend. I'll be helping the missus move house, but I'll be in the area, as she's moving not too far from me.
Oh and I can lend you a breaker bar and speed brace along with the right socket for wheel nuts too. Should make the job quicker if you can both do tyre changes at the same time. With enough practice we might even shape you in to the SAU-SA pit crew. :)
Sam, tried to call your mobile but to no aval. Anywho, got the extra set of car stand - thanks go to Ash and Darren, cheers boys.
No worries fella, anytime! pitty i wasn't home when you came, heard you had a few issues finding the joint...... :)
Will be good to see your line at a much better ride height and handle ALOT better! Next would have to be ECU after the diff your getting?
yeah, it was dark. i was tired and it took a while. ECU only if its too good to pass upon, same goes for TURBS or whatevers. Thanks to Ash, it was confimed that my o2 sensor has gone to o2 sensor heaven. great
btw, you guys have cat (animal that is) or neighbours have one, when i went out the car not long ago i saw paw prints and some scratches on my headlights - no happy jan. gonna have to buff it out now, doh!
Nah no stupid cats with us, and i havn't noticed any around, But i do keep the line under a car cover under the carport so it wouldn't scratch mine!
would like identical to yours now wont it.
Yes yes it will look identical to mine......... except for that front bar of yours, I should have kept mine.........NOT!
Edited by Deluxe
height adjustable mate, u can choose how low u want it. they are currently set at 355mm front and 345mm back (as per Sydneykids setting), i used to have it set 330mm front and back, but had to raise it for the bodykit. btw the spring rates on these are pretty solid, sort of like your old sileighty, so hope u dont mind the solid ride :P
ROFLMAO you should have seen the look on Pete's face when the brakes locked up - actually my face was just as surprised. Its driven by a chick now, she drove it like it had a standard clutch. She was like twin plate?..ok. ROFL
So how'd you go over the weekend fellas...
...and more importantly when do i get my tools back? :)
all went well... except for a certain nut that got snapped and nearly drove me and Duc crazy :) thanks to Andrew and Darren for dropping over to help out.
was funny when Darren dropped around and Duc was tightening up wheel nuts, and Darrens like.. "is that my wheel brace?" he must have picked it up from you and Darren didnt know :) ah, u had to be there i guess.
Yeh yeh that was funny, and i did know about it......... but must have come out sounding like i didn't know!
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
