yep fred from pro trans did the box for me i think its gonna be a big difference especially with the trans brake neva used one .. has anyone here used a trans brake whats it like...
Edited by campbell
  • Replies 74
the hardest thing about using a transbrake is getting used to not hitting the brakes when you hold it flat but its easy
just get into stage hold the button until you hit the right boost or rpm
i leave the line at 5000rpm with 10 psi boost
any questions pm me
put a boost gauge and 5" rev tacho close to ur steering wheel so u can c it straght and clear. I have 3 speed in mine. 1st u switch your transbrake solenoid on, hold the button then rev it to 5,000 or something, boost will hit 15-18psi. leave the button then you'll get "quickest launch ever". dont hold that button for too long, 5-6 sec max, other way u will cook ur trans. get a big trans cooler !, and dont press it again when you launch, your trans will go back to reverse and brake ur auto internals. autos are jsut like a tune and engine, you need correct stall size to suit ur turbo, and cam and then retune it to match everything... very hard man. You bought the best auto for drags, good luck
Love the sound of the T51R, always have and probably always will :P
As for being the quickest, I'm not sure about times but there was an R33 running a factory-capacity RB25, making 795rwhp getting around Brisbane, was built by Hardcore before they ceased operations and had NIS33 on the plates. Also, 40RCD (now TRY09) might be worth checking too, I don't know if it still runs an RB25 bottom end but last time I saw it, it was running some very decent times. It was definitely 2.5 litre when it was running mid 10's, and I'm fairly sure it was still 2.5 when it broke into the 9's too, but I don't know about now :)
Best of luck ;)
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
