Hey govich what do you mean by that?
Just went for a little drive again, what I notice is that it spools quickly to 0 and then I can hear a pschhh sound as if its being released.
I quite don't get it. The car is running fine. Its as if its a skyline with no turbo on it.
  • Replies 47
Posted Images
Going by the picture, could it be anything to do with the turbo?
Hopefully the thing is installed. Actuators maybe?
Can anyone tell me if this is right? I have circled it on the picture below.
Cheers
OK. Is this an accurate description of the problem?:
Engine idles fine.
Engage a gear, try to accelerate and it works fine with light throttle opening (boost gauge reads <0).
When you press the gas pedal a bit more, the boost gauge snaps to 0 and you hear a constant pshhhh, the car stops accelerating and engine starts running like a dog, blowing black smoke etc.
If so, i can tell you with 100% certainty there's a leak.
Engine idles fine.
Actually your right on everything except the part where i start hearing that pshhh sound, the car isn't struggling, its as if its running as a normal car without a turbo. Thats why it feels like the boost is just being released at 0 instead of what 10psi.
Weird?
If it does start running like a pig and blowing black smoke etc, then it's between the compressor and throttle for sure - the AFM reads a certain airflow value, the computer dumps the required amount of fuel in, but the air is leaking out somewhere so the AFR is way out..
Otherwise, if it's well behaved, the wastegate opening prematurely (or just not functioning..) is my guess, though then i'm not as sure since it's never happened to me - the leak has.
Edited by govich
I actually don't have that problem, the black smoke.
I do however have a remapped ecu... before the turbo and fmic my afrs were set a bit rich because the guy who remapped it set it as if a fmic and the new turbo was in?
The boost controller is fine since I just got it today.
Before it had the stock T piece and it wouldn't go past 0 still. It did the same thing but now with the turbotech boost controller it feels as if the car is running stronger probably because it only allows it to spool more boost but just releases it at 0.
So you think its the wastegate? It is an internal wastegate btw
i'd be pulling the dump pipe off to make sure it isn't fowling with the wastegate (to make sure it isn't stuck open) and to check the condition of the exhaust wheel. it could be that the shaft is broken also.
Yeah, the fact that it isn't blowing black smoke or running like a dog eliminates the intake, leaving either the actual compressor itself, or the exhaust side. Either way i'd say the problem's in the actual turbo itself (including internal wastegate).
Cheers
i only have a garrett to compare it too..
but i would say the bearing cage is upside down.
they must have tapped a thread into the bearing housing to screw the fitting in.
the area you circled should have the oil drain bolted to it.
Edited by dangerman4
I guess all I can do is to get it checked professionally.
Mind you that the turbo is brand new.
I wouldn't have a clue on how to remove the turbo.
Guess I would just have to spend more money to get it checked.
Thanks guys for the help anyways
Edited by aquariuz6
in that picture it doesnt look like the wastgate is stuck open
any way of removing the piping into the turbo and check that the wheels spin?
Umm Crave don't quite get you there when you say remove the piping? which one?
Also the part that I circled, is that supposed to connected like that?
Looks like it should be a bigger connection or something because of the bolt threads thats there on the side
Edited by aquariuz6
can you take a pic from underneath the turbo looking up at it. where the oil drain is conected.
cheers
the inlet piping from your air filter ...
easier to do than the exhaust, just to use your fingers to see if the turbo is spinning.. if not its seized completely and turbo is cactus
the oil feed is using a banjo fitting, looks fine - there are other types of fittings that could have been used, that is what that bolt hole would be for - that one does look like the type used for the oil drain backs .. this where you heading Daz ?
That line on the top is supposed to be for the oil return on the bottom of the turbo. The top is for oil feed and the bottom is for oil return. In other words, someone has turned the compressor housing and exhaust housing and has made all of the oil and water lines upside down. Pretty odd how they have done it because it would have been a fair effort to get that banjo bolt into the oil return aswell.
Turbo will have to be pulled off and all of the nuts around the back of the compressor housing and exhaust housing need to be loosened off and you need to spin the housings around the right way.
BTW i would stop driving the car the way it is.
Thanks, Mike
yep..
to me it looks like the lines have been put on upside down.
he said a panel beater installed it...
if its the case then they would have tapped a thread into the housing and filled the
bearings up with metal filings.
i would say its shagged...
take a pic from under the car.. then we will know for sure.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
