Hey govich what do you mean by that?
Just went for a little drive again, what I notice is that it spools quickly to 0 and then I can hear a pschhh sound as if its being released.
I quite don't get it. The car is running fine. Its as if its a skyline with no turbo on it.
  • Replies 47
Posted Images
Going by the picture, could it be anything to do with the turbo?
Hopefully the thing is installed. Actuators maybe?
Can anyone tell me if this is right? I have circled it on the picture below.
Cheers
OK. Is this an accurate description of the problem?:
Engine idles fine.
Engage a gear, try to accelerate and it works fine with light throttle opening (boost gauge reads <0).
When you press the gas pedal a bit more, the boost gauge snaps to 0 and you hear a constant pshhhh, the car stops accelerating and engine starts running like a dog, blowing black smoke etc.
If so, i can tell you with 100% certainty there's a leak.
Engine idles fine.
Actually your right on everything except the part where i start hearing that pshhh sound, the car isn't struggling, its as if its running as a normal car without a turbo. Thats why it feels like the boost is just being released at 0 instead of what 10psi.
Weird?
If it does start running like a pig and blowing black smoke etc, then it's between the compressor and throttle for sure - the AFM reads a certain airflow value, the computer dumps the required amount of fuel in, but the air is leaking out somewhere so the AFR is way out..
Otherwise, if it's well behaved, the wastegate opening prematurely (or just not functioning..) is my guess, though then i'm not as sure since it's never happened to me - the leak has.
Edited by govich
I actually don't have that problem, the black smoke.
I do however have a remapped ecu... before the turbo and fmic my afrs were set a bit rich because the guy who remapped it set it as if a fmic and the new turbo was in?
The boost controller is fine since I just got it today.
Before it had the stock T piece and it wouldn't go past 0 still. It did the same thing but now with the turbotech boost controller it feels as if the car is running stronger probably because it only allows it to spool more boost but just releases it at 0.
So you think its the wastegate? It is an internal wastegate btw
i'd be pulling the dump pipe off to make sure it isn't fowling with the wastegate (to make sure it isn't stuck open) and to check the condition of the exhaust wheel. it could be that the shaft is broken also.
Yeah, the fact that it isn't blowing black smoke or running like a dog eliminates the intake, leaving either the actual compressor itself, or the exhaust side. Either way i'd say the problem's in the actual turbo itself (including internal wastegate).
Cheers
i only have a garrett to compare it too..
but i would say the bearing cage is upside down.
they must have tapped a thread into the bearing housing to screw the fitting in.
the area you circled should have the oil drain bolted to it.
Edited by dangerman4
I guess all I can do is to get it checked professionally.
Mind you that the turbo is brand new.
I wouldn't have a clue on how to remove the turbo.
Guess I would just have to spend more money to get it checked.
Thanks guys for the help anyways
Edited by aquariuz6
in that picture it doesnt look like the wastgate is stuck open
any way of removing the piping into the turbo and check that the wheels spin?
Umm Crave don't quite get you there when you say remove the piping? which one?
Also the part that I circled, is that supposed to connected like that?
Looks like it should be a bigger connection or something because of the bolt threads thats there on the side
Edited by aquariuz6
can you take a pic from underneath the turbo looking up at it. where the oil drain is conected.
cheers
the inlet piping from your air filter ...
easier to do than the exhaust, just to use your fingers to see if the turbo is spinning.. if not its seized completely and turbo is cactus
the oil feed is using a banjo fitting, looks fine - there are other types of fittings that could have been used, that is what that bolt hole would be for - that one does look like the type used for the oil drain backs .. this where you heading Daz ?
That line on the top is supposed to be for the oil return on the bottom of the turbo. The top is for oil feed and the bottom is for oil return. In other words, someone has turned the compressor housing and exhaust housing and has made all of the oil and water lines upside down. Pretty odd how they have done it because it would have been a fair effort to get that banjo bolt into the oil return aswell.
Turbo will have to be pulled off and all of the nuts around the back of the compressor housing and exhaust housing need to be loosened off and you need to spin the housings around the right way.
BTW i would stop driving the car the way it is.
Thanks, Mike
yep..
to me it looks like the lines have been put on upside down.
he said a panel beater installed it...
if its the case then they would have tapped a thread into the housing and filled the
bearings up with metal filings.
i would say its shagged...
take a pic from under the car.. then we will know for sure.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
