yes, find somone with the same car with zero missfire problems. then raid their set-up for their coil pack loom. it's only a short piece, easy to swap. make sure you just change 1 thing at a time, so start with your orig set-up. then try loom. then try coil packs, then ignitor etc. also i'd suggest if you are running more boost than stock or plan to go for BCPR7ES (they come gapped at 0.8mm) as they are one heat range cooler.
can anyone tell me if letting the ignitor just hang without being attached anywhere is ok?
Its a pain putting and removing the the center valve cover.
Ive heard of a couple of guys here whove killed a ignitor from letting it just hang there....
  • 3 weeks later...
i will bring a old thread up as i dont want to start another thread on splitfires etc
my problem is that my r33 miss fires from around 4800? thru to 7000rpm im guessing as the vct kicks in it starts miss firing mods are
stage3 slidingperformance hiflow
intercooler
3" from turbo no cat
walbro fuel pump
now ive only had the hiflow for about 3 days now,and since bolting it on it miss fires on all boost settings including stock 7psi, before with stock turbo it would only do it anything above 7psi so i could run stock 7psi wen it would carry on and could rev it cleanly... i was using .8 gap on my plugs so yesterday i explored and regapped the plugs to .6 they are a ngk plug heat range 7...now this has fixed all my miss fire problems runs like a dream on 7 thru to 13psi
now if since i regapped to .6 it fixed my miss wat was the weak link before that? coils? stock ecu? ive ordered splitfires thru sliding they sould be here within the week,im not fussed if they were my problem but i wanted to get them anyway b4 powerfc so ive got it all sorted b4 it goes for a tune..so have any of u guys got a clue as to why .6 gap runs perfect and .8 gap onwards it misses terribly.
sydneykid give me some info! u seem 2 be the man around here lol
Justin
Edited by l0WRB
intercooler
walbro fuel pump
Justin
.6 means less of a gap to jump for the spark, like when the coils are worn etc, on healthy coils you can put the gap back up!
same issue i had!
I would have tested the coil packs first...
there is a thing in DIY about it if i recall.
well would stock coils handle 250rwkw i wasn't sure if they would so thats why i wanted to upgrade the coils its only $600
stock coils fine a 250rwkw-will be fine for alot more power to as long as they are in good nick- I changed mine at 300rwkw
whilst at the Veilside workshop earlier this year I was poking around their 7 second, over 1000hp R32 GTR... guess what. standard coils. not sure if they run them all the time, but it was definately using them whilst I was there.
like mr660hp said. the coils are great providing they are in tip top shape which after 10 or so years in a hot engine they generally are not in good shape.
thats probably the main reason i changed mine as mine are in 1993 r33 and are gettin old and would only cause the miss fire after they heat up!
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
