Stock gts intercooler/performance
Guest skybound
im kinda new in terms of turbo cars and have just purchased an r33.... sorry if these questions are lame! but is a stock r33 intercooler any good or should i get it changed - also what should i first start to add or change on my car to improve its performance.. basic stuff to start :D
https://www.sau.com.au/forums/topic/13562-stock-gts-intercoolerperformance/
Hi Skybound,
The stock intercooler is not much good at above factory boost, so if your after performance then a front mount intercooler(FMIC) is a must.
The first thing is to replace the factory exhaust system, a full exhaust from the turbo back is best. Then things like increase the boost, pod filter etc.
See'ya:burnout:
I agree with shuto-boy, you don't need huge-ass intercoolers, since you'll experienCe l ag if it's too big
and as paul said, don't bother yoursElf with the branded intercoolers as thats just an extra 1ooo bux on the price
juSt go a suitably sized (for thE amount of power) custom core, frOm a tRuck or whatever, and get that put in
welcoMe you too btw as well :)
p.s - cAn you please buy mE a nEw keyboard while yOu're out???? thIs o ne is ROOTED!!
Did someone say intercoolers?:)
Stock intercooler is a BAD place to start modifications.
It offers very poor value for money when you are chasing 'the basics' and specially with only the stock turbo.
If you have a budget of $3k or less leave it alone for now, and just make sure you have the other bases covered first.
Unless of course you are made of money (New turbo's?) or like losing to much less modified skylines in races.:)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
