I just finished running the new motor in on the dyno and did a base tune
The vehicle has undergone alot of Development now
Engine
Nitrated R33 GTR crank
H beam Eagle Rods
Venoila 9.2 Comp Pistons
Tommie Head Gasket
Solid Lifter Conversion
Big cams
GT 1100 hp bb turbo
2 speed powerglide
2 stage single sprayer nos kits
It has made 485 rwhp on 10 psi @8500rpm
I will post the Dyno sheet on 2morrow with the run on 30 psi
hopefully make around 800 rwhp
I should be at the track in the next 2 weeks
I will also post picts with photos of the new engine bay and if someone can host a video clip ill appreciate it
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/
  • Replies 51
Posted Images
Hello everyone
I just did a safe tune on the vehicle and it made a total of 648 rwhp @ 30 psi on a 10.2 AFR
I am going to do some more Tuning on it to get it to 720 or so RWHP But im waiting on a MSD dis 4 before i can run more boost and before i start bumping up the timing.ill hit the track next wenesday night.Aiming in the 9`s somewhere
Hopefully towards the end of the year i can run in the high 8 area,
I havent installed the CHUTE yet but i will after i get back on wenesday.
ILL post up some Dyno Picts and Videos soon3
Its still the RB25 Block just with GTR crank,Eagle Rods,Venoila 9.2 comp Pistons.
The car makes power to 9000rpm which will be fun at the track
When everyone sees us up there come up and say hello
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2542799
around 6300 without nitrous
but i got nitrous on till 18 psi so i can gety on boost quickly and it gets on boost around 5700
Ive had lnemup plates for around 4 years
and the venoila pistons are pretty good quailty so i shouldnt have a problem
Edited by MR331307
https://www.sau.com.au/forums/topic/135859-lnemup/#findComment-2544094
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
