Should be getting my exhaust soon and was wondering if it is necessary for wastegate integration as part of the system.
If there is no wastegate integration is there a chance of blowing the turbo up and has the stock exhaust got this integration.
Dont really know what Im talking about so please let me know.
Andrew
https://www.sau.com.au/forums/topic/13590-wastegate/
But with a wastegate pipe it improves............ the flow and reduces turbulence just after the turbine
turbulence i s the disruption of air ... if you have turbulence, then the air flow is not linear, and if the air isn't all going one way at the same time, you'll have a reduction in the flow and and increase in restriction
https://www.sau.com.au/forums/topic/13590-wastegate/#findComment-265811
I recently got my dump pipe done and its been a fantastic improvement. I went with a single pipe with a really wide opening at the top. Having had a look at the standard pipe its obvious how much better this is. The stock one on the 32 has a cast iron flat section just about blocking the wastegate area off... its horrible.
A larger single pipe is probably enough for most people. And theres little guarantee it will be better if you buy one with a separate wastegate pipe. This is because it may rejoin too early or too late causing similar turbulence issues within the system.
You'll see improvements either way, however the difference between the 2 styles of dump pipes probably cant be felt on an arse dyno (only a real one).
Red17
https://www.sau.com.au/forums/topic/13590-wastegate/#findComment-266982
I'm geting my exhaust done next week. I pikd up a exhaust housing gasket, $20 and have since taken to my exhaust guy. He is going to weld up a new plate and incorporate in a seperate wastegate dump.
the dump off the back of the turbo will be a rapid increase to 3', the wastegate pipe will be 1"1/2. The exhaust guy has recently done something similar to another GTST, but the wastegate pipe entered the system down near the cat convertor.
My question is - "is this TOO far back? I know the further back the better. But we are talkin about 1 - 1.5m here".
"should I also thermal wrap any of the dump pipe???"
btw full 3" zorst turbs bak with hi flo cat and rear muffy etc etc..
tks.....
https://www.sau.com.au/forums/topic/13590-wastegate/#findComment-271177
opposed to GTS-t VSPECs whos comes in at a right agle :)
Whether apart of the normal exhaust or a seperate screamer pipe, that joins back into the main exhaust at any section, or not at all.. wont hurt your turbo..
Id say the ultimate is an exhaust dump, one pipe with a secondary wastegate screamer which never enters back into the main pipe. Thats my next goal when the exhaust comes off..again.
https://www.sau.com.au/forums/topic/13590-wastegate/#findComment-271415
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
