Hey all,
I have the stock TV/CD/Sat Nav system which is playing up. I use it to play CD's and I think she is packing it in.
Sometimes the screen will not come up, then 15mins later, it beeps and POPs up, when it does come up and plays CD's after a while the screen freezes and music stops. Turn car off it goes back down but then will not come up again
Could this be a loose connection or a fuse? Where is the best place to start looking?
Cheers,
Daz
Edited by DazR34
https://www.sau.com.au/forums/topic/135931-r34-stock-tvcdnav-issues/
  • 2 months later...
I had the exact same problem with mine. After a while the system decides to not work completely (instead of freezing up after 10-15 minutes). Just recently the screen has started to pop up every time the car is started up... with an error message in japanese.. i think it is somthing along the lines of "please contact the program desk"
I'm completely bummed about it.. to it to a car stereo guy over here in WA and he was completely clueless.
Is there definitely nothing that can be done?
Does anyone have any suggestions as to what other system can be put in so the i can keep the motorised pop up screen?
  • 1 month later...
I can make the motorised screen work up and down without the gps deck controller..
but not the nav..
I got switch to make it move and remove the tv and swap it to my MIO handheld GPS..Its easy if u can find tv about that size to replace
i post a pic if u want..
had problems with my old 34 as well..screen didnt pop up but it constantly beeps non stop for like 5mins which like fkn happens almost everytime i drive..
hahahaha...nick u don even hav the nav anymore
yea put up some pics...wanna see ur good work
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
