well 1 tank wont last you the whole day. i usually fill up in Goulburn at Caltex during the lunch break, not becuase im low on fuel, but because i dont want to be low on fuel at the end of the day and have the car to surge through the corners. doing that saves bringing jerry cans and will get you home without having to fill up on the way back... plus you can buy half decent food rather than be over charged for a 3hr old burger at the track!!!
  • Replies 212
Posted Images
my car doesnt like changing fuel without doing an ECU reset it's annoying as because in theory it should just learn to like it and i am sure if i left it long enough it would but a perfect example was our trip to the coast at the time i was running shell optimax extreme filled up down the coast with like 58 litres so litterally almost empty with caltex vortex and it ran like shit the whole way home aweful throttle responce.
either way i am a maybe for the track day pending my soreness :O
just how much stuff have you done to your car?
Mine behaves quite happily (unless i'm thrashing it - then i can pick the difference, slightly) on any of the 98ron fuels, and probably Castrol Vortex as well.
I can only see that being a problem if a) Your car is hyper sensitively tuned with a very highout put engine or b)You've never had it tuned at all...
i can tell you leech's car is pretty much stock. its a bloody neat example though... :O
my car doesn't give a crap which fuel is in it, it just goes when i tell it to. Vortex is no different to the other fuels. in fact it comes out of the factory at 100 Ron and is blended down to 98...
stock ecu can't be tuned so i am sort of stuck with it :laugh: oh well as i said i stick to the one type of fuel and she performs nicely :kiss:
piggyback/remap?
i thought stock ecu's ran overly rich and - in general - like a dog on our fuel?
they do run overly rich and that may have been why my car was going like crap using optimax extreme would have leaned it out a little from it's usual stupidly rich then putting in a 98 ron with no ethanol made it even richer again and i am guessings that's why i ran like crap as it had to re-adjust.
In regards to the fuel thing i guess it's how you drive your car + the condition it's in i have read stories on here where people get like 300km's out of a tank either they are the biggest lead foots around or there car needs a service/tune. around town we usually get 440 - 460km's highway even more so thats why i was hoping i could make it up to the track have a run around and get back without having the fill up.
anyways back on topic i am keen to go still :laugh:
piggyback/remap?
I find (and i have a tuned PFC) that i depending on my right foot, i get anywhere from 300 - 360km out of 45L (what i invariably end up putting into the car, never get much lower) around Canberra (I do alot of km a week - 500 to 600 usually).
On Highway being a good boy i get 500+ and well, being naughty the worst i've seen is 270.
yes it was fun.
Whats the warmest it can get before your engine/turbo isnt happy while at the track? or everyday driving for that matter.
its inversely effected.
The colder it is, the more your turbo/engine likes it, however your tyres and the road (what you want to stick to) go off the colder it is.
Tyres prefer hot sticky conditions.
why god? why?
Stop making up fuels, it's Caltex.... pfft.
I think i'll give it a go, probably be the only auto POS on the track, and the heaviest... but it'd look cool seeing a 'volvo' dominating over some stock R33's. i doubt i could do much against anything modified more than i am.
being auto and heavy, just be mindfull of your brakes. i probably dont have to tell you this, but when your on the track, just go for say 3-4 hard laps than have 1-2 slow laps to cool everything down. thats how i keep the temps down. otherwise everything over heats and you have to pull off the circuit....
Edited by Frink
I might be asking a dumb question but is that for heavy auto cars or everyone?? :P
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
