Thought I might open this up with a list of mods, wont put in a future list coz I don't think the page is big enough :laugh:
Bought the car with Pod, Teins, Nardi, 16in AVS, Newly transplanted Rb20 ('uknown' k's), blitz boost gauge and around 160,000k's on the clock. Now it has the following mods and ~208,000k's on it:
  • Apex Pod (Replaced the K&N oily one that came with the car)
  • 40mm Alloy Rad
  • Uras Bodykit (Now sold and back to standard)
  • HKS Oil Cooler
  • Rainbow Sox
  • Extreme HD Clutch
  • Bleed valve @ 0.8Bar
  • Bride Zeta
  • Reinhard Catback
  • Speco Water temp gauge (soon the be replaced with Defi Din gauges)
  • Kaaz 2 way diff
Here are some pics. will get more when its lighter, stupid video cam takes shitty stills in low light.
Interior when I bought the car.
Engine bay prior to 40mm Rad going in.
With 40mm Rad.
post-18824-1159173464.jpg post-18824-1159173998.jpg post-18824-1159174178.jpg
With Uras attached.
Bride Zeta.
post-18824-1159173201.jpg post-18824-1159173242.jpg post-18824-1159173274.jpg
Reinhard. Complete with removable mufflers and silencers (excellent for street use).
Here is a vid of my drifting with the exhaust fitted:
That's all for now. Konect.
Edited by konect
https://www.sau.com.au/forums/topic/136000-konect-1990-cefiro/
NICE VID!
what is the tune like on it? sounds a bit laggy? love the RB sound though!!
Nah probly more my driving that makes it laggy. Was my first run for the night so I was a bit out of practice, later on I started keeping the revs up while on handbrake so it wouldn't bog down, then slamming third for the last corner.
Tune is the normal jap tune (rich as a mofo!) and comes on about 2.5k revs which is about normal. Not too bad to drive :)
Thanks for the comments :yes: Will get better footage next month.
nice car mate, it reminds me of the one in bigx in hpi9 (except yours is better), i cried when i saw what they did to that car :nuke: ..... and the laurel :):)
lol yeh i have that vid! OH my poor car, at least it doesnt get rolled on its roof...yet, touch wood :D
Edited by konect
  • 1 month later...
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
