They're big, cheap, and American.
Having said that I have been tempted to try them - they make 11ty-billion different types of calipers!
As long as the design is OK(ie are stiff enough across the bridge, take a large diameter rotor / thick rotor etc), they should work fine...
Give it a shot and let us know how you go!
If you need some radial mounts machined I might be able to put you on to someone
cheers
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533227
haha I can be the guinea pig!! :O
I'm very tempted at the moment... Basically I've found a full kit that uses the superlite 4 piston caliper, a two piece 330mm rotor, braided lines, pads, bias valve, brackets etc for not much money... basically a little bit more than it would cost me to buy caliper extension brackets, rebuild my existing 32 4 pots, and getting some DBA 5000's, so yes, very tempting...
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533523
As Ronin said, Wilowood make a caliper for every man and his dog. So jsut check the model of caliper and make sure the pistons arent smaller then what you are running at the moment.
Im with you, i often look at the Wilwood gear and what they can be bought for. They have calipers that go for $5000 each, but they also have good 4 pot and 6 pot calipers that are between $600-800 each so is tempting :laugh:
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2533907
wilwood have a good selection of pads available,
its just a matter of getting the right one.
we started using a harsh compound and new rda slotted rotors
would only just last a rally. now use a softer compound
and get 2 rallies out of rotors with similar stopping power
and not so touchy
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2535418
Thanks for the feedback guys.
Dougmo, which compound do you use, and are they readily available here??
The caliper that comes with the kit is the Superlite 4, so I'll have a look into the piston size. I wouldn't mind going the Superlite 6, but it's probably a bit overkill, and I'm going to have trouble getting them inside a 17 inch rim...
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2535530
Yeah, seen those mate, that's where I got my pad choice from :huh:
Thanks though.
no probs.
btw, you shouldn't have a problem fitting the 6-piston calipers in a 17" wheel as Wilwood have a brake kit for the sierra cossie with 6-piston calipers, 323mm rotors and they fit inside 17's.
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2546041
Really?? Cool, I'll have a look into it, and see what they say.
Cheers man.
Btw, this is the kit I'm looking at, optioned with Polymatrix E's and Slotted, Zinc coated rotors
http://wilwood.com/BrakeKits/Pages/04/index.asp
https://www.sau.com.au/forums/topic/136224-wilwood/#findComment-2548401
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
