hmmm well not much to report, but i'm back from Japan, and i have some new found inspiration from the DMAX ceffy!
also fitted
KTS traction rods
VS-ONE rear pillar brace
strobies in reverse lights
did a little more cleaning (FUN)
got tomei cam gears aswell and Gates racing timing belt to get fitted. Also got a couple other little things that will set the car off. New look coming in the next few months :)
  • 1 month later...
  • Replies 176
Posted Images
well new belt and cam gears fitted up, did G1 round 3 - good result qualifying in top 16 - drew christian pickering first round, he beat me 6-4, 6-4 on the two runs...
with only doing 2 rounds of the 3 round series, i ended up 16th for South Australia G1 Championships. ;)
The car is now gonna get pulled down again and freshened up... should look HOT!!!!
Also going to upgrade the turbo again (power hungry lol) so the hks gt2540 is now for sale - its been running on 1.2 bar at the moment (around 220rwkw). click link for details :thumbsup:
More updates later, as things start to happen
I've got some other bits for sale, and will update bits for sale as i find them. As i'm gonna do a shed clearout of all my bits and pieces.
Here's a pic from G1
  • 3 weeks later...
UPDATE
cars been pulled to pieces, new turbo should be here this week, gotta finish of sanding it all and then off it goes to get piping done and paint sprayed >_<
hoping for it to be done by the end of the year. you may or may NOT recognise it as the same car... lol. ;)
  • 1 month later...
well with help from my fellow FULL TUNE members, and SIMON from MORPOWA - i've been slowly getting this thing done.
there's 2 major mods going on at the moment, exterior and power.
only going to go into detail about the power side of it for now and unveil pics once car is all finished.
POWER
well the hks2540 is long gone, and 1400r sourced me a dmax manifold from japan which is now on the car. I also got myself a Garrett GT3076r IW with the .6 front and 56trim wheel with .63 exhaust housing from SIMON at MORPOWA he also modified the wastegate to have a larger port and also larger flap. Coming off the back of this is an awesome screamer dump / front pipe with flex join from AM PERFORMANCE here in Adelaide. I modified my intake pipe which i had on the previous setup to suit this turbo, its not perfect but it will be more than sufficient for the job.
still have to fit the nismo adjustable fuel pressure reg that i've got, but that is a simple bolt on item.
I am nearly at the point of starting the engine and hearing this thing run again, but i'm still waiting on the return of my I/C pipe modded, hose for oil drain - then all sorted.
260+ is the goal for this setup by what boost... now that is the question...but i will find out soon enough.
EXTERIOR
i have a 'few' more new things which will make the car stand out and make it more individual over other ceffy's, including other pieces from other cars which have been modified to suit... more on that when its all finished though!
i will put up a pic of how the car looks at the moment though.
cheers
-Matt
Edited by huddy
well paint colour should be revealed soon :thumbsup:
ultimately i would like 280+rwkw, but i do have gtr injectors with fuel reg, so unsure if i have enough fuel from this and also walbro intank pump.
also skeptical on the whole setup as its on a rb20 based engine.
should find out in the next month or so :D
  • 3 weeks later...
well... it runs!!
slight problem, need to modify the awesome front/dump as it is a little low :P
but other than that, it was good to start the engine in about 2months (or more)!!!
hopefully i'll get a tune next week, just have to get the dump/front modified again first.
got the GT3076r fitted up (with the wastegate ported out and larger flap fitted)
DMAX stainless manifold fitted (welded on extra gusset) (+ nissan ex mani gasket)
AM Performance Stainless screamer front/dump *TUFF AS*
new braided oil feed line and water lines, re-sleeved with heat sleeving
ally intake pipe was modified to suit with 4"-3" reducer
also fitted a nismo adjustable FPR
enjoy the pics.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
