  • Replies 176
Posted Images
***UPDATE***
i've bought another cefiro shell - plans for it (over long period of time):
- weld in roll cage to Australian CAMS specs
- all seam welded
- front guards tubbed
- completely gutted
- air jacks
and on the current car - just getting a wheel alignment then onto the dyno again :ermm:
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
yeah loved the GT3076r - wont be changing it.
mine had .63 IW housing (modified) and was great - it did have more in it, but engine was pulled out before could see what more could get from it.
There have been no other updates atm, just i have a cefiro on stands in the shed with no engine :P and no motivation :P:cool::mad:
huddy, wtf ? I'm all eyes and ears on your car/setup.
Btw, thanks to you I did some improvements to my A31. No I don't get that shitty tail fishing and instable car. It was alignment problem.
Whats with your car ? What are you gonna do in the end ? Go RB30?
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
