Hey guys.
Ok so ive established that the Justjap JJR intercoolers are good and worth the money ($550 for a type 2 kit)
My goal is:
FMIC + Exhaust then crank up the boost.
Good idea?
OK lets say it is :laugh:
I completed my tax return today, should be getting about $900.
Car is almost stock, except for a POD and BOV.
My Dillema is, do I go for the exhaust or Intercooler or something else.
Can only afford one at this time.
The Exhaust i had my eye on was the X-Force 3.5" Turbo Back system ($799 for mld steel, $950 for stainless steel)
The Intercooler kit im also looking at is the JJR Type 2 Intercooler kit.
So if I could get peoples thoughts on:
*Zorst, FMIC or other
*What effects will each have on my car
*Any other sugestions you feel are relevant
Thanks guys :kiss:
https://www.sau.com.au/forums/topic/136284-dilema/
Whats this split dump buisness? (don't know what that means :laugh: )
Also would there be much difference between a 3" and a 3.5" system?
X-Force does both the 3" and 3.5" turbo back.
Im thinking X-Force mainly because I had an X-Force cat back on my previous car and it sounded great.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2534076
do a search on split dump pipe and you will see... the split dump seperates the wastegate gas then rejoins about 40cm down the dump... makes big difference to a single bell dump..
i wouldn't go anything bigger then 3" on the exhaust... unless ur running twin turbo or have 400+rw/kw
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535035
good way to spend $900 in my opinion:
- full turbo-back exhaust
- turbotech boost controller set to about 10psi
- oil and sparkies changed
- 1 hour on dyno to adjust the timing
you want a 3" exhaust.. no bigger, no smaller...
probalby the greatest mod that one could EVER do to a turbocharged vehicle...
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535060
turbo back exhaust, then front mount followed by boost and then powerfc it to get maxium bang for buck - but its gonna cost more than 900
Edit: X-force has a nice rumble to it, depends on what you want - quiet or loud.
Edited by emsta2003
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535127
I want loud...ish.
As in, legal and not overly droney.
Does anyone know if the X-Force has this split dump that was mentioned? If not, any other reccomendations on a full turbo back system for $900 or less.
Also is it worth paying more for stainless steel? Ive heard mild steel is more than fine for many years.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535767
you can get the split dump front from batmbl (hes a member on these forums), and then just get the cat back from x-force and attach it to whatever cat you got running
thats going to work out much more expensive than the full x-force kit, and not give much of a power difference.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536089
Ok well theres the Xforce turbo back
$799 for Mild Steel
$950 for Stainless steel
Theres also the JJR Split dump for $125
Whats the difference between a 'front pipe' and a 'dump pipe' ??
Does a split dump make a big difference?
Again what sort of difference would I notice going from stock to the full Xforce turbo back
And what difference ontop of that would I notice if there was a split dump?
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536131
no you wouldn't notice the difference between a split dump and a bell mouth dump.
the dump pipe is the pipe off the turbo. the front pipe goes from the dump pipe to the turbo. the x-force pipe is a 1 piece pipe. it has both in the front pipe.
the jjr dump pipe also requires a front pipe.
Edited by mad082
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536294
how can you dyno tune a stock ecu though? didn't think there would be much gain to be had.
i didn't sasy "dyno tune" i said time on the dyno to adjust timing
a dyno is just rollers so that the car can be driven as on the street but still monitored (eg listening for pinging)
with the car strapped to the dyno the mechanic can see how the engine runs (eg is it making the right amount of power?) and adjust the CAS to change the base timing (give it more power!)
this usually costs around $100-110 depending on the workshop and is highly recommended
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537336
i agree with mad082. get an x-force turbo back system, get a bleed valve and set it to 8-9psi, maybe even 10. the standard side mount shud support this, but if u want to be more safe and economical, buy a gtt side mount. after this u shud pick up at least 20-30kws at the wheels
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537999
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
