I know i could have searched this, but i wouldnt get an answer to my question directly, more so i would have to read through pages and pages of unrelated information.
Anyway, I was wondering what pads people are using and what they think of them.
1. In terms of overall performance (stopping ability, fade, etc.)
2. In terms of brake dust
3. In terms of noise
Any help is much appreciated
Cheers, David
https://www.sau.com.au/forums/topic/136405-brake-pads/
Do not use Bendix Ultimates if:
U dont want ur brakepad to literally sh$t dust
U dont want to wake eveybody up in the street and the next street over, especially when slowing down from normal driving speed.
Brake fade is good BUT mine starts after a spirited drive, not fade but less bite, but it could be bad rubber.
Endless all the way
BTW BNR32 with new RDA slotted rotors and Bendix Ultimates :)
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2562644
I have an R34 and with Ultimates I have belted around the track lap after lap and never got any fade. They are dusty as hell though, prone to squealing and eat rotors for dinner. They wear out fairly quickly but for a performance oriented pad they are cheap. They do stop well though.
I just put some Ferodo DS2500's in last week and went to a track day on sunday. I'm told they last twice as long as Ultimates but yet to find that out. They give a firmer pedal. They stop well but have to push harder. They didn't fade. No noticeable dust after one track day. Only squealed when really hot.
Apparently my rotors were glowing red yesterday after 220 down to 170km/h stab and then 190 down to 70km/h stop straight after.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2566835
What is the difference between DS2500s and DS3000s? Anyone know? Price difference?
3000s are only meant for race use, apparently they will destroy your rotors when they are not hot.
2500s are fine for normal use as well as hard track use, and even come oem on some hi performance new cars.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2576574
I was using DS2500s for a while.
I didn't notice any degradation in performance when cold, and it took a fair amount of effort for me to fade them (even on my underbraked car). The only thing is they cover your rims in dust if you even look at your brake pedal. And they squeal when cold.
I'm on OEM pads since I did a brake upgrade and got pads with the calipers, but as soon as these pads die I'll be going back to the Ferodos. Dust or not, they work.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578552
The DS2500s are a "sprint" pad. They require almost no heat to come into operating temperature so they work from the get-go, and they can handle a reasonable amount of abuse. My mate's Formula Ford ran DS2500s in the NSW State Championship, where each race is around a dozen laps, or about 15 mins. No fade. They're not heavy cars, but the rims are tiny which means the brakes are tiny, and they work their brakes harder than most of us ever do.
The DS3000s are an "endurance" pad. They need more temperature to come on (they are noticably weak when cold), but they'll handle more heat and I believe last longer. If your race isn't won or lost based on your ability to stop in the first 2-3 corners because all the racers know there's plenty of time later, its a better pad.
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578566
I currently use Delphi(AP) Lockheed Type ZR(50-850degreesC) brake pads on my GTR32 and i run the sprint,clubman and national circuits on Queensland Raceway, they bite well and get up to temp fast, didn't experience brake fade with them. Initially when bedding in i had quite a bit of squeal with them, after 1 track session they don't squeal at all, i don't see too much brakedust with them too. The endless CC-X (50-700degreesC) pads are pretty good as well...
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2578699
winmax the best pads ive had driven in or heard of(apart from da brembos in evo 8mr) fair bit of dust good for everyday driving. took car for a rap down the royal wid lots of hard braking didnt fail or fade once no noise and ive had them on car for bout a year wid ten thousand kms and only bout half done 0-500 operating temp good stopping power all the way through the temps but tink you can only get them through bel garage not the cheapest at $ 220 for the fronts and $180 for the backs im very happy wid em
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2582138
Um, after doing ALOT of research, the way the Bendix Ultimates are made (And the whole Bendix range) they shouldn't be run with slotted rotors at all as the slots will just tear them apart.
That's interesting to hear. What would be the best pad to run with slotted rotors then?
https://www.sau.com.au/forums/topic/136405-brake-pads/#findComment-2583211
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
