which head is best?
Guest drift_me_silly
no msn on this machine, swapping labs in an hour...i'll try msg u then...where do you go to drift around here, who do you use for mech. work, how do you afford the sweet machines that are skylines? -i'm in the making of a career...namely mine...as i said.
in time.
If the rules are still the same, then the head off a larger capacity engine will cause a REDUCTION in C/R when fitted to an engine of smaller capacity (presumably the combustion chambers are bigger on the bigger engine). Now, this may allow you to run more boost, but the engine will be far less tractable 'off-boost'.
It was often the practice in the days of L-series engines to do things like fitting a L-16 head on a L-18 block to get a bit more compression.
If you are after serious grunt, then trying to fit the RB20 head on the RB25 seems more the way to go. Or you could simply port / polish a RB20 head for your RB20 block so that it breaths better.
Hi guys, RB25 and RB26 are 86 mm bore and RB20 is 78 mm bore. So if you try and put an RB25/26 head on an RB20 block you will have a mismatch in diameter of 8mm. The water jackets are in different places and, if I remember rightly, the oil galleries are different as well. That's why there are none around.
Want more capacity out of your RB20? Try an RB26 crank and rods and 4AGZE pistons, makes 2,336 cc's. There's a lot of info and discusion about this in the past on the forum, do a quick search. Also www.meggala.com has a lot of info as well.
Hope that helps.
Hi S13 Silvia, suggestions follow your questions.............
***What do you reckon would be a good price for rb26 crank and rods?
Shop around the forum they come up from time to time, prices vary from $200 to $500
**Is it possible to use the rb20 pistons with the rb26 rods?
Never tried it, I know the gudgeon pin is larger diameter in the little end of the RB26 conrod. You could either machine the piston for a larger gudgeon pin or bush the RB26 little end for the smaller RB20 gudgeon pin. Either would probably work OK, I would lean towards the former as a larger gudgeon would be better as long as the necessary machining doesn't weaken the piston too much.
**What's the availability like on getting the rb26 crank/rods?
They come up from time to time on the forum. Be watchfull, act swiftly, as they seem to sell fairly quickly, and have your money ready.
Hope that helps.
Hi drift_me_silly, check out the posts by JOnJOn he has a 2.4 litre RB20.
Watch the costs though, they add up and can easily exceed the cost of doing up an RB25DET.
Good luck, let me know how it goes.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
