Batmbl Gb #3: Twin/split Dump & Front Pipes In One + 3" Hi-flow Catco Cats (optional)
hi guys
BATMBL will be in charge of the GB, so all Q's, PMs & payments will need to go to him.
The 1st & 2nd GB was a huge success, so the 3rd GB is now open.
The pipes are made here in Australia and are a 304 grade, 2.2mm stainless steel. They will be suitable for both your standard turbo and/or a hi-flowed stock turbo.
The cars & prices for which the pipes are available:
* R32 GTST/GTS4 or R33 GTST - $380 DELIVERED
* R34 GTT - $410 DELIVERED
OPTIONAL:
The Catco cats available:
* 3" small body BOLT ON Catco cat (ceramic inside) - GB price only $160 including delivery
* 3" large body BOLT ON Catco cat (ceramic inside) - GB price only $230 including delivery
* 3" Catco cat BOLT ON (metal inside, 5" round body **not 4" like Magic cat & Metal cat**, 200csi cell - 706.2 CFM! **Outflows Magic cat & Metal cat**, EPA & CARB approved) - GB price only $360 including delivery
If you buy both the pipe & cat, just combine the two prices for total cost including shipping.
Payment method: Direct deposit - (PM BATMBL for bank details, along with your address)
Delivery Method: Registered post
Terms: Once full payment is made, the pipe will be sent within 1-2 working days. If there is no stock left, the pipe will be ordered to be made. This is due to the fact that a high intake of people is expected at once and stock may run out quickly. In the case of this occuring, you may need to wait up to 5 days before the pipe is sent after your payment has cleared. These pipes are hand made, one by one, not on a production line, so it does take some time to make them. This also ensures you get a perfect fitting pipe.
If you agree to all the information above and want to be in the GB, please place your interest in the thread along with which pipe (& cat if you want one also) you need.
cheers
Edited by Driftn 180
  • Replies 113
Interested in dump pipe (and possible cat) for R34 GTT sedan. Will this fit a sedan with standard turbo and apexi cat back exhaust. Thanks :happy:
Interested in a dump pipe for an R33. PM sent
Edited by Lazy-Bastard
I'm interested in a split dump to suit a R32 gts4, as well as a 3" small body BOLT ON Catco cat.
I run the stock turbo atm, but I'm holding onto a R33 turbo that I'm saving to go on in the distant future (with possible hi-flow). Regarding the split dump pipe, Will there be any hassles in terms of fitment to the upgraded turbo when/ if it goes on?
Cheers :angry:
Rflirty4,
Im not 100% sure on fitment with 4dr, there may be slight modification needed, but it could also be a direct fitment. if its needs adjustment, the exhaust shop would be able to do it fairly easily, but from memory no one has ever returned a R34 GTT pipe because it didnt fit and im sure there would have been a 4dr customer at some point or another.
R32GTS4,
The dump & front pipe for the R32 & R33 GTST is the same, so i dont see a problem with fitment if using the R33 turbo (high-flowed or stock) on your R32 GTST.
cheers
gt-t_r34,
I have put the payment details in the thread (2nd post). the pipes cant be sent out until after the GB even if payment is made now since i wont have them delivered until it closes. this way i have the amount of parts needed and they are delivered in one hit, and everyone gets the discount.
cheers
SKY 34,
Payment will need to be made from now till Friday 13th Oct (GB closes 10th Oct). Anyone on the list after 13th Oct that hasnt paid will have to be taken off the list.
mrgilly,
The previous GB was left open till closing date to give people enough time to check the GB section and put their interest in buying the products. I wont have any of these parts to send out until after 10th oct as they will all be delivered to me in bulk, and thats how i get the discount, which passes over to you guys, sorry about the time it will take but this way everyone gets a chance to be part of it.
cheers
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
