Batmbl Gb #3: Twin/split Dump & Front Pipes In One + 3" Hi-flow Catco Cats (optional)
hi guys
BATMBL will be in charge of the GB, so all Q's, PMs & payments will need to go to him.
The 1st & 2nd GB was a huge success, so the 3rd GB is now open.
The pipes are made here in Australia and are a 304 grade, 2.2mm stainless steel. They will be suitable for both your standard turbo and/or a hi-flowed stock turbo.
The cars & prices for which the pipes are available:
* R32 GTST/GTS4 or R33 GTST - $380 DELIVERED
* R34 GTT - $410 DELIVERED
OPTIONAL:
The Catco cats available:
* 3" small body BOLT ON Catco cat (ceramic inside) - GB price only $160 including delivery
* 3" large body BOLT ON Catco cat (ceramic inside) - GB price only $230 including delivery
* 3" Catco cat BOLT ON (metal inside, 5" round body **not 4" like Magic cat & Metal cat**, 200csi cell - 706.2 CFM! **Outflows Magic cat & Metal cat**, EPA & CARB approved) - GB price only $360 including delivery
If you buy both the pipe & cat, just combine the two prices for total cost including shipping.
Payment method: Direct deposit - (PM BATMBL for bank details, along with your address)
Delivery Method: Registered post
Terms: Once full payment is made, the pipe will be sent within 1-2 working days. If there is no stock left, the pipe will be ordered to be made. This is due to the fact that a high intake of people is expected at once and stock may run out quickly. In the case of this occuring, you may need to wait up to 5 days before the pipe is sent after your payment has cleared. These pipes are hand made, one by one, not on a production line, so it does take some time to make them. This also ensures you get a perfect fitting pipe.
If you agree to all the information above and want to be in the GB, please place your interest in the thread along with which pipe (& cat if you want one also) you need.
cheers
Edited by Driftn 180
  • Replies 113
Interested in dump pipe (and possible cat) for R34 GTT sedan. Will this fit a sedan with standard turbo and apexi cat back exhaust. Thanks :happy:
Interested in a dump pipe for an R33. PM sent
Edited by Lazy-Bastard
I'm interested in a split dump to suit a R32 gts4, as well as a 3" small body BOLT ON Catco cat.
I run the stock turbo atm, but I'm holding onto a R33 turbo that I'm saving to go on in the distant future (with possible hi-flow). Regarding the split dump pipe, Will there be any hassles in terms of fitment to the upgraded turbo when/ if it goes on?
Cheers :angry:
Rflirty4,
Im not 100% sure on fitment with 4dr, there may be slight modification needed, but it could also be a direct fitment. if its needs adjustment, the exhaust shop would be able to do it fairly easily, but from memory no one has ever returned a R34 GTT pipe because it didnt fit and im sure there would have been a 4dr customer at some point or another.
R32GTS4,
The dump & front pipe for the R32 & R33 GTST is the same, so i dont see a problem with fitment if using the R33 turbo (high-flowed or stock) on your R32 GTST.
cheers
gt-t_r34,
I have put the payment details in the thread (2nd post). the pipes cant be sent out until after the GB even if payment is made now since i wont have them delivered until it closes. this way i have the amount of parts needed and they are delivered in one hit, and everyone gets the discount.
cheers
SKY 34,
Payment will need to be made from now till Friday 13th Oct (GB closes 10th Oct). Anyone on the list after 13th Oct that hasnt paid will have to be taken off the list.
mrgilly,
The previous GB was left open till closing date to give people enough time to check the GB section and put their interest in buying the products. I wont have any of these parts to send out until after 10th oct as they will all be delivered to me in bulk, and thats how i get the discount, which passes over to you guys, sorry about the time it will take but this way everyone gets a chance to be part of it.
cheers
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
