hi
;) i need some help in buying two skylines. one skiline is for my little bro who will be on he's p's.
and the other is for me for i dont realy care on the power but i dont mind the kick.
iam after r33's but not sure on the years.
is there any skyline r33s with turbo that a p plater can drive in victoria?
is it better to buy off a car dealer in australia were i can test it out etc. or import them througth a company?
.iam very mix up on which is best to spend more and have less worries or the cheaper way?
i have been trying to do the research and i been greating just crap in information and verations of r33s
and that the r32s are better
thanks guys
dave
:wave::):):huh:
  • Replies 56
lbfalcon maybee you should come to Victoria before you start throwing the laws around. That law wont be in place till next year and after the NSW Death Toll on P plater Drivers theres a chance it may never come in... but for now you can drive turbo cars in Victoria the only problem is Power to weight ratio.
P platers can drive R32, R33 not sure about R34 though having 206kw.. but i have seen a fair few P platers driving them around.
sweet thanks
it saves my little bro getting the car inpounded
so i will buy stock for him
thanks guys
a stock R33 is over the power to weight limit. therefor a p-plater in victoria cannot drive one legally. end of story.
You might want to read his post properly before you tell him not to 'throw laws around'.
He is 100% spot on. NO factory turbo R33 can be driven by a victorian p-plater. They are over the power to weight limit. period.
i think i will just buy him a stock none turbo to save him getting pulled over all the time
but he can allways put one on later any way
it will be safer for him any way
thanks
R32 turbo's are legal to drive on P's as far as I know but still wouldnt be reccomended as a first car.
Don't by a non-turbo expecting to turbocharge it later, you'l regret it. Better to sell it and buy a turbo model.
lbfalcon is correct. R33's are over the power to weight ratio. I was pulled over for it when I was on my P's.
if your getting a R33 get a Series 2, have ABS and air bag..plus more importantly looks more modern....
try going for 40th aniversary model and Ho...forgot to tell you, if you follow the skyline scene the R33 value has plummeted......i mean gone down like mad.......so great time to buy....
got GTST S2 for 16500 (4 months ago).....and love it...
i think the r33 is a much better GT car than the R32 and silvia.
some one sent me a pm about buying and told me to go for the 1996 models
i dont mind the R32's but i rather a new car because i'm driving a '90 EA falcon S pack atm
but i pre had a VL witch was a dream untill it blowen up on the freeway
ps i wasn't speeding lol dam lemon
made grate juice stanes on the road tho :(
but i'm not sure what R33 i want
eg... turbo, non turbo...
btw do the R33 come with semi/automatic?
>_<
ABS is an option....its not standard on S2's
you may wanna learn your laws before you try correct him also...
R33's are ILLEGAL to drive. the p platers you see driving them, are driving them ILLEGALLY.
The R33s are newer = better.
The only reason why some consider R32 better is cos they are smaller (crappier too ;)) car :bunny:
comments like these shit me and the amount of slurs coming from r33 owners on this forum suprises me.
Not everyone wants to follow the crowd like a tool and buy the cheapest S1 burgandy r33. :O
A big mystery as to why the r33 are dropping price ;)
r33's are illegal for p-platers but they still tend to drive them. Although with the new p-plate laws next year the cops may get more strict on the power/weight law.
I suggest to look into an r32 if he would like to be legal.
Well maintained r32's have been floating around 13-15k dollar value for many years and havent had any major decline as of yet.
Good luck in your search :(
- Patrick
how is your comment any better than his?
The amount of R33 bashing from R32 owners on this site is the real joke.
But how dare the R33 owners argue back and defend their choice of car... ;)
fair enough i lashed out cause im sick of hearing all the slander towards the r32's
If the r33's would want to argue at least put some evidence as to why they are crap. I wouldnt have over-reacted if the poster at least stated his reason as to why.
The original poster seems to be now deciding over both models and a comment like that wouldnt be helping. So why dont i post a comment worth the exact value as the slander in regards to the r32
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
