Hey guys, ive just got a simple question to ask. Ive get a pair of 6.5 inch splits and would like to know if any here has installed spilts themselves before or have taken it to an audio specialist ie. tonkins, mobiltek. If a home job, is it hard to remove the door trims etc tc or If you guys had it pro installed would any1 recommend tonkins?
thanx in advance
https://www.sau.com.au/forums/topic/13668-car-audio/
  • Replies 57
Originally posted by Miss_Nismo
complete audio cause i work there ;)
Are you offerring a discount? :)
anyways, yeah Ill give you a visit sometime soon
btw tonkins quoted me ~80 to install speakers, but with my splits(kickers k6.2) would require mdf therefore he sed ~$130 yikes!? is this to much? oh Im not going to tonkins now that miss_nismo has sugested hers, but as a benchmark as to how much Im looking @ paying.
Thanx for your informative responses
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-269019
thats sounds like a very good price miss nismo.
Another thing which i might add is that is it possible to get just purely the speakers installed ie. by complete audio. y? b/c im getting an amp not long from now and would want to get the speakers directly connected to it , thus no need to uncut/clip wires from the headunit to then have to rerun the wires to the boot. Furthermore, it would save me money in the long run as it seems they cost another $150 odd to run to an amp in which you have alredy got an amp kit for. Can pro's just do the speaker step for you?
thanx
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270487
Hi guys
I just installed some Kicker 6.5 splits in mine. Very Easy and hardly worth paying a pro for. The door trims aren't complicated. There are 3 screws along the bottom of each door. One screw in the bottom of the door handle (hole). The rim around the door lever just clips off (take care). The power windows switches come off in one bit and are just clipped in. On the passenger side there are 2 screws holding the handle in. Remove the cover on the bottom one. The top one is under the power window switch which will just unclip with a screw driver. Then just lift the door trim up. The speakers can be mounted to the black plastic ring which is stuck on the factory speakers. No need for any MDF. As for the wires, pull back the rubber seal along side the dash and you will see a hole even with the bottom of dash. Run your wires through there and into the door. Make sure you have enough slack wire so the door can open fully but not too much as it will get caught in the window mechanism.
Hope this helps.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270520
Sime: thanx for your reply, its very helpful. Well, then im going to try and install it myself but it that fails then i guess Ill have to get it pro installed. btw where did you mount your tweeters? Im thinking of putting them on the back of the mirror plate but atm with a glance it seems to be too big, actually more like it buldges out a bit. Also, how do your speakers sound .. any sound deadening used?
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270537
I've just got the tweeters on the dash next to the window facing up. It's easy to run the wiring from there between the dash and the A pillar. They're not the optimal position for sound quality as they aren't pointing at you and the sound supposedly bounces off the front window. Unless you've got a very good ear, you won't notice the difference. The problem is they are visible from the outside. You could always put a Maccas drive through sticker there to hide them. The other one is hidden behind the reg sticker. I thought about the mirror plate but decided I couldn't do a neat job of it there. As for sound deadening, that's on the cards. My speakers sound awesome at the moment but I do get a bit of rattle as the door trim vibrates against the door.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270548
yes, Im concerned about visibilty also since the car is prodominately situated in public places. hhmm..need window tinting! btw is your speakers running of your headunit or amp? On the issue of sound deadning, ive heard that some ppl have used pink batts..seems like a cheap alternative but then again it doesnt contain the properties which sound deadning products possess. Approx. how long did it take you to install your speakers..particularly door panel removal and midrange installation?
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270558
You should run your speakers off an amp. Head units don't give out enough power and can actually damage your speakers. I don't know much about sound deadening except it's expensive if you buy the real thing. I don't know how good the alternatives are. (Anyone else out there know?) Speakers took less than an hour. That doesn't include installing the amp. Once you've figured out the first door, the second one will only take a couple of minutes to get off. You'll need a drill to screw in the speakers as you'll have to create the holes in the plastic ring. I just used self tappers rather than drilling a hole first.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270571
your input has been very much appreciated sime =D
yes im going to get an amp and will run speakers of them.
Im going to give installing the speakers a go in a few hours, hope it wil be fun without alot of cursing and screaming. rofl.
cheers
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270580
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
