Hey guys, ive just got a simple question to ask. Ive get a pair of 6.5 inch splits and would like to know if any here has installed spilts themselves before or have taken it to an audio specialist ie. tonkins, mobiltek. If a home job, is it hard to remove the door trims etc tc or If you guys had it pro installed would any1 recommend tonkins?
thanx in advance
https://www.sau.com.au/forums/topic/13668-car-audio/
  • Replies 57
Originally posted by Miss_Nismo
complete audio cause i work there ;)
Are you offerring a discount? :)
anyways, yeah Ill give you a visit sometime soon
btw tonkins quoted me ~80 to install speakers, but with my splits(kickers k6.2) would require mdf therefore he sed ~$130 yikes!? is this to much? oh Im not going to tonkins now that miss_nismo has sugested hers, but as a benchmark as to how much Im looking @ paying.
Thanx for your informative responses
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-269019
thats sounds like a very good price miss nismo.
Another thing which i might add is that is it possible to get just purely the speakers installed ie. by complete audio. y? b/c im getting an amp not long from now and would want to get the speakers directly connected to it , thus no need to uncut/clip wires from the headunit to then have to rerun the wires to the boot. Furthermore, it would save me money in the long run as it seems they cost another $150 odd to run to an amp in which you have alredy got an amp kit for. Can pro's just do the speaker step for you?
thanx
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270487
Hi guys
I just installed some Kicker 6.5 splits in mine. Very Easy and hardly worth paying a pro for. The door trims aren't complicated. There are 3 screws along the bottom of each door. One screw in the bottom of the door handle (hole). The rim around the door lever just clips off (take care). The power windows switches come off in one bit and are just clipped in. On the passenger side there are 2 screws holding the handle in. Remove the cover on the bottom one. The top one is under the power window switch which will just unclip with a screw driver. Then just lift the door trim up. The speakers can be mounted to the black plastic ring which is stuck on the factory speakers. No need for any MDF. As for the wires, pull back the rubber seal along side the dash and you will see a hole even with the bottom of dash. Run your wires through there and into the door. Make sure you have enough slack wire so the door can open fully but not too much as it will get caught in the window mechanism.
Hope this helps.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270520
Sime: thanx for your reply, its very helpful. Well, then im going to try and install it myself but it that fails then i guess Ill have to get it pro installed. btw where did you mount your tweeters? Im thinking of putting them on the back of the mirror plate but atm with a glance it seems to be too big, actually more like it buldges out a bit. Also, how do your speakers sound .. any sound deadening used?
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270537
I've just got the tweeters on the dash next to the window facing up. It's easy to run the wiring from there between the dash and the A pillar. They're not the optimal position for sound quality as they aren't pointing at you and the sound supposedly bounces off the front window. Unless you've got a very good ear, you won't notice the difference. The problem is they are visible from the outside. You could always put a Maccas drive through sticker there to hide them. The other one is hidden behind the reg sticker. I thought about the mirror plate but decided I couldn't do a neat job of it there. As for sound deadening, that's on the cards. My speakers sound awesome at the moment but I do get a bit of rattle as the door trim vibrates against the door.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270548
yes, Im concerned about visibilty also since the car is prodominately situated in public places. hhmm..need window tinting! btw is your speakers running of your headunit or amp? On the issue of sound deadning, ive heard that some ppl have used pink batts..seems like a cheap alternative but then again it doesnt contain the properties which sound deadning products possess. Approx. how long did it take you to install your speakers..particularly door panel removal and midrange installation?
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270558
You should run your speakers off an amp. Head units don't give out enough power and can actually damage your speakers. I don't know much about sound deadening except it's expensive if you buy the real thing. I don't know how good the alternatives are. (Anyone else out there know?) Speakers took less than an hour. That doesn't include installing the amp. Once you've figured out the first door, the second one will only take a couple of minutes to get off. You'll need a drill to screw in the speakers as you'll have to create the holes in the plastic ring. I just used self tappers rather than drilling a hole first.
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270571
your input has been very much appreciated sime =D
yes im going to get an amp and will run speakers of them.
Im going to give installing the speakers a go in a few hours, hope it wil be fun without alot of cursing and screaming. rofl.
cheers
https://www.sau.com.au/forums/topic/13668-car-audio/#findComment-270580
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
