post-19743-1160949703.jpgpost-19743-1159667422.jpgpost-19743-1159667066.jpgpost-19743-1159666374.jpgpost-19743-1159666704.jpgi have some parts im looking to get rid of as i will be selling the car;
PRICES DROPPED MAKE SOME OFFERS PEOPLE
CAN POST MOST PARTS OR PICK UP
WILL INCLUDE POST ON SOME PARTS
all parts good or very good or new condition and located in se melbourne.
ADDED-brand new low mount stainless steel tube exhaust manifold (with NEW crap gaskets)
hks copy,same with all these parts, selling due to selling me the car. $280ono price dropped
TO SUIT RB20DET OR RB25DET
1 x BRAND NEW genuine nissan exhaust manifold gasket for rb20det $75 ono
1 x standard rb20 cross over pipe with blow off valve $40 ono
1 x standard rb20 intercooler with pipes under guard and brackets $40 ono
1 x set of (2) coil over sleeves to suit any car with 50mm od struts, with springs $80
1 x set of r32 gtr centre gauges with plug and 2" of loom gc $125
1 x set of NEW whiteline adjustable castor bushes for gtst KCA331 $75 ono
1 x pair of r32 gtr nismo style front bar vents (fibreglass) $100 RELISTED
i will have other parts available in about a week and a half,
-standard r32gtst turbo in gc
Edited by DOUGMO
  • Replies 66
there are still in the packet,(it has been opened) but never been used or greased,
I can post for $10 extra
aight ill take it man, PM me your bank details and ill send you my shipping adress.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
