Just got the rb20 a new crank, main and big end bearings. The crank was measured at an engine shop, and the correct grade bearings were then installed going by the crank size.
Just put the engine back in, and the motor is so tight it cannot be turned by hand or the starter motor.
What do i do now? should i tow it?
You should not try any further to turn the motor over, by whatever means - you'll only do damage. It will be a case of unbolting the crank and doing it by the numbers......measure all the bearing clearances using something like plasti-gauge. Well, thats what I'd do. Measuring the bearing clearances directly is the only way to be sure, AFAIC.
Another possibility is that you have a 'tight' thrust face, have you measured the end float on the crank ??
If you can't turn by hand, theres something wrong.
Didn't you or they try turning the crank before installed into the car?
Might also wanna check the valve timing.
i am quite confident that the bearings are the correct size, crank was measured to see if it was out of round etc, and the plasti-guage was used. there was bugger all end float, but it wasnt measured.........
also, forgot to mention, i had it running for a minute or two, then it stalled and now its siezed. but it was very tight before also. VALVE timing also checked.
Edited by HRthirtyone
Dude... take it apart, and double check everything. If you try anything dodgy to save yourself ripping it out and opening it up, your jsut gonna break something cost yourself mroe money and be back at square 1.
Unfortunately its the only way to be sure in a case like this.
when it started the first time how much oil pressure did it have ?
ANY ?
Ummm, some pretty important details. Sounds like some clearances were not correct and that, possibly combined with low or no start-up oil pressure has caused a bearing or bearings to pick-up. I really don't think you've got any choice but to at least drop the sump and check the crank and bearings. Should be no nead to remove the head. Of course all this assumes that something really unuasual hasn't occured (eg seized starter....extremely unlikely).
didnt check the oil pressure when it started, because i started it outside the car, and it was running rough, i just checked all the injector plugs and coil pack plugs, then it came good, idled on all six for about 30 sec. then stalled. Oh, plenty of assembly lube, and it has a new starter motor that is all good
the ONLY thing you need to worry about when first starting a fresh rebuild is oil pressure.
when you have the engine on a engine stand, and before you bolt the sump on, pour some oil into the pickup "with the motor upside down" and get a friend to slowly turn the crank around so the oil pump can
a: prime itself
b: pump oil to the crank and other essential areas that oil is required.
it only takes a couple of minutes but you will never have any oil pressure issues on first startup.
I hate to say it but its spanner time for you.
any sort of death noises b4 it stalled? when rebuilding its important to get ALL measurements cheaked, then as ur instaling pistons once measured, turn the motor over by hand afta each piston is installed, thus making sure that its not excesivly tight, e.g poor thrust face or end cap clearences
Mine with the plugs in was pretty difficult to spin over by hand.. But you could feel it was free until one of the pistons came up on its compression stroke.
The RB20 that came out all though it still had ~145psi in all cylinders was very very free even on its compression stroke.
A little sideways on the topic but is there an engine building thread that has all the obvious things to check in it like:
Bearing clearance's and end float clearances
All bolt torque specs and torque orders for the main and head bolts
Tricks for pre-oiling
Startup check lists and cam/lifter wear-in procedure
Assembly tricks like vasoline in the oil pump
Just an idea, but it would make a good sticky thread for those that build engines but would like all the data available on the one page.
Cheers,
Ian
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
