  • Replies 89
Posted Images
Yay
Finally home
(5:15am)
And yep, worst photo of me ever.
Ive realised why LJ beats all the boys at darts, pool and pretty much anything that requires skill - its cause we are drunk when we play ;)
hahahhahah sif!!! drunkness is an advantage!
I'm the champ :O
(you forgot to mention I am the hole-in-one champion at putt putt hehe)
Thanks for inviting me to the partay liz!!! so much fun.. great night!
Tis was a good nite @ lizbertz!
:( @ everyone
omgz then and i went to a chec returant the day after on another friends bday and we has shots on absin (sp?) 60%, Did it with the flameage and the sugur.... it was awesme! ZOMG!!!!!!!! Then went shots crawwlling down william street to the various pubs to get shops. I wasnt drunk COZ I WON $70 on the pokies w00tssss
If that meks any sense..hmm crsp crap
I'm the champ :P
Yes yes, there may have been a game of putt putt a while ago, i can sort of remember.........the details arent coming to mind at the moment though :P
ummmm full of cup cakes cant eat anymore......... ahhhhh now i can
Send them here.
I am not kidding
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
