in order left to right
225/45/r18 stretched on 18x11 dunlop v02 tyre
18x11 w/ 225/45/r18 fitted... stock a31 rear guards
random pics of my car... i really need to get my ass into gear with it
x2
mrs car finally has her new wheels on
18x9 +15 R disk (sacrificed alot of dish to get caliper clearance) w/ 225/40/r18 not really stretched
18x10 -5 O disk 235/40/r18 stretched
https://www.sau.com.au/forums/topic/136835-random-pics/
did we import that cef? looks awfully familiar
better hope not! haha :angry:
Car looks tough, dont even need those flares hahahah :laugh:
2 Questions:
1 > How did you get the cooler to fit so cleanly behind the front bar?
2 > What brand bonnet is that and who did you import it through?
Edited by konect
https://www.sau.com.au/forums/topic/136835-random-pics/#findComment-2543119
no plans to slide?
not building it to look pretty in my driveway lol
just other priorities have arose... the s15 needs new coilovers, mrs and i are moving so there goes next few months worth of pay cheques... and im picking a daily ceffy up this week hopefully (if anyone knows of any rb20de manual a31's for sale TELL ME ASAP!)
yeah funky you guys did - its the one that had all the headaches with that john dudes transport company...
cooler is a stupid fitment... everytime i take it off it never goes on properly again... its a little more to the rhs than the left... Eastbear cooler piping and r34 gtr factory front mount... brackets to hold cooler are right below the tow hooks
bonnet was from yahoo auctions in jp
https://www.sau.com.au/forums/topic/136835-random-pics/#findComment-2543323
adz? :P good to see it gettin back to its former glory.
Damn you southies with your jap style number plates... damn you all!
https://www.sau.com.au/forums/topic/136835-random-pics/#findComment-2554300
more updates... after doing the sums... im not in a position to really get it rego'd... so my wonderful girlfriend found a cheap bargain manual rb20det with snapped timing belt for sale in qld... imported by autoshop 2 years ok... registered and everything... genuine wonder kit on it too... pretty much stock
so my blue one will be for sale in about 4-6 weeks... new cefiro will be here next week
yay 2 ceffies in the shed :laugh:
and dont worry - swapping all the good bits over to the new burgundy one... itll just be street registered!
and yes front bar not sitting properly... 1 ziptie eitherside... my driveway is shitehouse... so i figure itll give it extra movement
https://www.sau.com.au/forums/topic/136835-random-pics/#findComment-2555078
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
