HICAS vs No HICAS (Track use)
34 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
H.I.C.A.S. = Help I Can't Actually Steer!
It was one of the first things I got rid of on my R34, you'd turn in and a moment later the arse would sorta feel like it "fell over". I found it very unnerving. Throwing the Sydneykid Whiteline kit in and getting rid of the HICAS was one of the best things I did.
There is a thread on here about installing GTRGeoff's lock bar, and there was also an article in High Performance Imports magazine a while ago about removing the hydraulic system from R32s.
The main thing on the track with HICAS is that with the rear end steering you tend to get a sort of "numb" feeling from the back of the car. When you are cornering hard, you tend to "feel" the back end of the car through your seat. You can tell when the back wheels (usually) are starting to slide. When HICAS engages, you tend to loose that feeling. If not completely, it certainly deadens the feeling. It is not that it makes it any harder to steer, you simply lose touch with the road.
thanks guys!!! after having driven the car for about a month now and experiencing the things you guys are talking about I think I will remove it...
now the only question is whats the difference between Sydneykid's Whiteline kit and GTRGeoff's lock bar...
I think I understand the lockbar but what is this Whiteline kit you are talking about?
The only time I can feel HICAS actually doing anything is just after you turn in to a fast corner, doesn't have to be a sweeper just any fast, wide corner.... just after you brake and turn in, the rear of the car feels like it is just about to snap out on you... after a little while you learn to ignore this 'sensation' and just attack the corner... its just for a fraction of a second that the rear feels a little light... worse thing you can do is correct for the slide you think is about to come...
The whiteline kit is as R33S2 describes and I would be looking at this before you worry about cancelling HICAS...
swaybars, springs/shocks, camber adjustment bushes, pineapples made a HUGE difference to the handling of my car... in comparison HICAS doesn't bother me
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
