  • Replies 86
what time does it start? No booking required right? Do I pay at the door?
Sent the L2S application for off, gonna ask them to fax a temp license on monday or tuesday just in time for the Wednday session......Anyone else coming on Wed?
im 85% to make it out there on thursday at this stage.. things are looking good.
we need blue battery triangles for this day, right?
There was no inspection last track day, and I did not have one, so not needed.
I just called Oran Park to confirm and they said the wed one is 110..............what happened to the $50 one??? well I guess I won't be going. The lady there was rude as......need to learn some customer service.
They are able to change with no notice, they must have changed it to a full day. I have to go back with numbers today, I will let them know there will be about 8 of us for thursday.
Lingeringsoul,
I just called OP to confirm that Thursday will be on for abour 6-8 of us. I questioned the change of Wed from a 1/2 to a full day. She said she would still allow $50 for anyone who wants to do a the afternoon only. Your call but she said you should still come.
You need, the following.
1. Road worthy car with good tyres.
2. Helmet Oz STD and head to toe non flammable clothes.
3. L2S licence. You must be a CAMS club full member (ie SAU) and buy a 12 month licence for $82 from cams.
Sometimes you need a Blue triangle for your battery and a fire extinguisher in the car, for a full run CAMS event, but not needed for these L2S days.
Thanks
Thanks
I am in with Corsair driver challenge car and slot car for testing as changed suspension settings for testing.
hope thursday is like today for you. cool weather, no rain, track was a little damp and a few puddles, but dried up. only 5 cars turned up. did 60 laps by 1:30pm, stopping as i was happy with my times and running low on fuel. should've brought a jerry can, no one was left by the time i left.
GP circuit + open pits + no traffic for only $110 = TOPS!
rofl thats not my old diff off to another new car is it? its a car whore
It certainly is. I think the deal was that I gave my almost new Nismo 2way to Dan and I get the old Nismo 1way in return but if it blows up he pays for the rebuild. I hope it's strong.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
