  • Replies 160
Posted Images
So it is all up and running now? What sort of power did you make?
yes i have been driving it for a month or so now... and no dramas!
f**k it goes hard too! ;)
However not yet dynoed... i need to purchase a power fc firstly... just pending $$$$$
Sweet when its all finnished I would love to come have a look at some stage! I want to see how the Turboed NA compares to a similar RB25det in a R32 :P
thats is f**king tight, wat rims are they (plus specs) good work.
hehehe thanks!!! They are my Work Meister Series 1's .... to be!!!!!!!!!!
Sweet when its all finnished I would love to come have a look at some stage! I want to see how the Turboed NA compares to a similar RB25det in a R32 :)
Sure thing!
It's a date! :)
looking good there tiff, i'll have to take a look at it one day too, wouldnt mind a bit of capacity in mine. those wheels look hot, i wanted those forever, the gram lights were cheaper but. keep us updated too.
update - just saw the numberplates, AK has got to be spewing
Edited by war32
  • 3 weeks later...
Unfortunately I will not be purchasing those beautiful work meisters any longer.. as the owner sorta smashed a gutter .... and well one rim is totally f**ked :P
However 51pry is going awesome!
The only things that have been replaced are.... the clutch master cylinder and one of the power steering lines... the engine is going sweet... no hick ups at all i am thankful to say!
She's getting a radiator flush, oil and filter change tomorrow... she's done just over 4000km's now
VERY VERY HAPPY with this set up!
I now have to find myself a new fuel regulator, an oil cooler...
and a power fc.. that is if my lovely bf doesn't decide to sell his 33 and sell me his .... :D
  • 4 months later...
WWWWWWWHAAAAAAAAAAYYYYYYYYYYYYTTTTTTTTTTTTTTT the !!!!!!!!!!!!
OMG>>>!>@!P"NIKFWE
what can i say but wow....that is quite a colour change......gonna have to catch up to see this things again...my god....HOT!!!
i am going the 25 conversion as well tiff!!!
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
