I was just outside having a smoke when I saw fuel pissing out from the bottom of the car after a quick inspection looks like I have a leaky seal from somwhere near the fuel filler area to where it joins the tank,
I turned the car around so it wasnt leaning towards the fuel cap or downhill and the leak stopped !!
Do youse think I just could have over filled it ???
I cant afford to be throwing away fuel , not at these prices!!!
https://www.sau.com.au/forums/topic/137234-fuel-tank-leak/
Could be a cap,
But maybe also a poor filler neck seal. They change these in compliance and don't normally seal everything properly.
Pull the filler neck assembly out and have a look and reseal everything!
I had the same prob. in my 180.
Cheers
Josh
https://www.sau.com.au/forums/topic/137234-fuel-tank-leak/#findComment-2553110
When I got back from Heathcote last week 26Degree heat I filled the tank with petrol and parked it in my garage.
After I came out around 30 minutes later a puddle of petrol was coming from the rear right corner.
This I was told was the expantion of petrol in the tank and excess is realeased.
The car was hot ,I filled it too much .
This is also the first time this has ever happened to me.
Hope this makes you breath a bit better, knowing your not flammable as your driving along :(:(
https://www.sau.com.au/forums/topic/137234-fuel-tank-leak/#findComment-2591907
