Hi guys,
As topic mentioned, I am looking for a high flow CAT to fit on my new exhaust system...
FYI, I have a full HKS system i.e. HKS dump pipe, HKS front pipe and HKS Hi power (silent) CAT back.
Now, the only thing left is the CAT. I am not sure where to go. Metal-CAT or XFORCE?
Does it make much difference?
Also, where can I get it in Perth (quickly) with flanges?
Any recommendation where to fit this system?
Thanks in advance guys
https://www.sau.com.au/forums/topic/137608-high-flow-cat/
MetalCat ftw!
group buy just ended unfortunately and were going for $280 + $65 if you wanted flanges
hard to find one in perth...a sponsor "Just SR" had a couple left over from a buy and they were pretty cheap. Have a look in the trader section and he should be able to ship one over pretty quickly from SA i think
https://www.sau.com.au/forums/topic/137608-high-flow-cat/#findComment-2562910
Thanks for the replies guys...
I have heard lots of good review about Metal-CAT...so yeah...most probably will go for it....
@arkon/anyone
Which exhaust shop do you reckon I should go to get the flanges done as I am still new in Perth.
Any helps/suggestions will be highly appreciated.
Edited by ecr33sky
https://www.sau.com.au/forums/topic/137608-high-flow-cat/#findComment-2563279
Cheers arkon
@lukits01
I am not sure the exact size (the exhaust is still on the way) but I am pretty sure it is slightly smaller than HKS Hi-power 409 (correct me if I am wrong). I personally prefer a quiet exhaust and hence the reason why I get this system.
Check this web add for the sound : http://www.hks-power.co.jp/sound/
https://www.sau.com.au/forums/topic/137608-high-flow-cat/#findComment-2564372
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
