Lucky that it wasnt hard enough to damage the engine.. it looks alright there.
ehhh, anyway, you could probably source out some cheap stuff on here ( Lights, Front bar etc ) and then send it away for repair.. will prolly be 3 - 4k i think.
Shame to see it like this, all the best mate.
that sucks :P
if you're willing to drive down to milperra, my mate owns a smash repairer, i can go with you to get a quote off him if you like.
Cheers mate.. but car isnt driveable atm.... the radiator is pushed right up against the fan belt etc. and condenser is gone...
Would be great if your mate could give me a quote if i send him some pics?
btw i think u r the guy who bought the head gasket of me? when u were rebuildign ur engine?
ahh yeah! i remember.
send me some high-def pics and ill send them over to him. try get as many angles and as detailed as you can, and a list of what you think is broken.
This looks worse than the damage i had inflicted on my car by a nameless bitch!!it was paid 4 by me in the end.luckily no other cars or public property was damaged in the process.
I was not insured and it cost me $3k but i supplied the parts.
Other places were charging $5k
good luck.Nice car u had there.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
