try telling any store that sells brakes that you have an "m spec" and they'll be rather puzzled
one store said they had a listing for r32 gts and that should cover all r32's... (well thats the impression i got)
no one else knows if r32 gtst 4 brakes are the same as r32 gtst's?
GTSt (all specs) and R32 GTS4 are the same.
GTSt, R32 GTS4, GTS25t and GTR (non-Brembo) all share the same pads.
They all share generally the same caliper except with different length brackets to attach them to the car allowing for larger discs.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
