Like explained before if a car the weight of a skyline only put 300 od newtonmts at the treads then it wouldnt move...
Gears and diff are torque multipliers hence the figure you get is accurate reading of what ur car is putting at the tyres...
Different gears will give u different torque readings...
  • 4 weeks later...
Model: Nissan Skyline R34 GT Saloon [R34 RB25DE] Neo, Tiptronic
Mods: Splitfires, 98RON fuel (UK) (Otherwise standard)
Power: 136.2 BHP @ 6000 rpm | 101 rwkw @ 6000rpm (At the wheels)
There is a bit of a glitch around the 5000 mark, does the variable cam come in at this point? Is there anything I can do with the fueling to smooth / lift the power curve?
Also does anybody know how I can determine the peak torque from this graph?
Edited by Sliver
Not Skyline but Pintara.
Car: 1989 Gli Pintara Wagon
Engine: CA20e
Mods: Extractors, exhaust
Power: 85.3hp (63.6kw) at the rear wheels.
And this is what it was done in.
  • 5 weeks later...
  • 3 weeks later...
Model - R31 series 3
Engine - RB30E
Modifications - k&n pod filter, High Tech exstracotrs, 2.25" cat back exhasut with cannon, adj cam gear, 282' crow cam (custom), r32 GTS-T 5sp manual, 3.7:1 LSD diff.
Dyno tune results: 118.6 rwkw
MISC look here for full specs.
http://forum.r31skylineclub.com/index.php/topic,58063.0.html
can some one put up a post at the start with peoples power results only just be easer to compare.
  • 3 months later...
Z32 300ZX
VG30DE
134.1 on RE Customs dyno
mods: Apexi pod, 2.5inch exhaust: front pipes, metalcats and catback. still running stock headers, harmonic balancer, flywheel and running stock tune.
future mods: extractors and ecu remap. hoping for 150rwkw. haven't decided if i am going to go to lightweight flywheel and harmonic balancer yet.
Model - 1986 R31 GX
Engine - RB30DE (30 bottom, 26 top) :rolleyes:
Modifications - Aftermaket ECU, chromoly flywheel, Nismo pressure plate, balanced rods, over 12:1 comp, N1 GT-R rings, GT-R water pump, GTS-T oil pump, RB25DE pistons, oil restrictors, crank grub screwed.
Power - 139.2 rwkw or 186 rwhp at 5800 rpm
MISC - Still running the turbo cams (very bad for n/a application) and still have the 2.25 press bent exhaust. With new cams, exhaust and rods, it should see +180 rwkw
ok, well i will list my 2 natro cars that i have had on the dyno (neither skylines though). will scan dyno sheets when i find them.
2000 n15 SSS pulsar
genie extractors
2" press bend system (which i want to get redone because it is just one we bodged up 1 arvo) with 12" centre resonator and lukey muffler (not a cannon)
k&n panel filter
fuel - dunno. probably 91 octane. can't remember
112hp atw (approx 84kw)
2000 mitsubishi magna (3.5L manual)
first run: 100% stock, rear muffler was a cannon, but rest of the piping was stock
159hp atw (approx 118kw)
second run: pacemaker extractors, 2.5" redback centre system (cat to rear axle), 2.5' lukey rear system k&n panel filter
170hp atw (approx 127kw)
1999 magna (same as previous one, manual 3.5L)
never dyno'd, but felt more powerful as the previous one had been thrashed a fair bit.
redback 2.5" exhaust
14.8 at willowbank with 2.18 60ft time
1993 R32 RB25DE GTS25
2.5" full system with race cat, K&N panel filter
first up it pulled 88.1rwkw...we found it out had a blocked fuel filter and shagged fuel pump
so after replacing both of them it pulled 111.2rwkw
then after the remap i had done today it pulled 122.2rwkw
so the remap, walboro fuel pump and new fuel filter it gained 34 odd rwkw
  • 3 weeks later...
update on where my car stands.
dynoed with:
spitfire coil packs ngk plugs
ported and polished head
K&N panel filter
and standard exhaust
down to 180bhp and 156lbft of torque from the stock figures.
since then ive added coby d12 headers (not ceramic coated or wrapped as yet)
standard catalyst into threeinch pipe to calsonic back box.
yet to dyno this set up ..(delayed due to 4wd issue)
also for info ..anyone with an r33 saloon (gts4 or rwd)the rear subframe is identical to a rwd coupe gts and therefore the whiteline kit listed ofr the gts witll fit ..(and makes a big difference)
  • 1 month later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
