Cant believe I could be f'ed doing this
http://www.djrperformance.com.au/dynographs.html
Very nicely inflated results there
and
oh look a Chassis dyno...not an engine brake
http://www.djrperformance.com.au/services.html
so
he was claiming rwkw's
  • 3 months later...
1989 Nissan Skyline R31 Silhouette
RB30E
GTS2 Extractors
3'' Straight Pipe
20 Degrees BTDC Ignition Timing
98 PULP
Also just going to mention that my car is over fueling and running extra rich so that would have taken some out of it.
2007 V36 370GT VQ37HR 3.7L V6 5SPD AUTO
Modifications:
Cat-back exhaust pipes
Hi-flow panel filters
Apparently car runs rich from factory, bit more power to squeeze out of it if I can lean of the a/f ratio a bit
Stock Power run done close to when I first got the car for reference:
  • 3 weeks later...
  • 1 month later...
+1
also love how the radiator hoses are put as a modification
I thought this thred was for dyno figures? apparently not.... Anyway, Ive only put down what was read out at the car show where the dyno run was done, And I thought the turbo r34 standard are 208kw and the gtr 280kw? From what I've read about a million times N/A RB25de neos do about 147kw standard?? is this wrong coz the thing will keep up with my mates boosted s14 no problem?
both the r34 GT-t and the GTR are quoted as having 206kw at the flywheel (all factory quoted figures are at the flywheel) however the GTR actually puts out more power. and yes, the non turbo is 147kw (again, at the flywheel) which would work out to be about 150hp at the wheels
  • 2 months later...
  • 3 months later...
  • 4 weeks later...
R31 Skyline Series III Ti
RB30E
Stock Motor Done Near 800,000K's - Runs A Little Off Beat
Runs a rusty old set of extractors with old stock exhaustand had 4.11 Diff ratio which was stuffed open wheeler "Just about to install 3.23 LSD"
New GTS1 Cam, Timing Kit, Plugs & Leads - Installed 6 Weeks Ago!
15" Ti Alloy mags
Does 10KPL Religiously & equates to almost 600K's Per tank
Am shortly contemplating in dumping the NA high comp motor that I've got with around 80,000K's on it and VLT auto trans that's only done a few hundred K's along with Hi-tech headers "Stainless" and 2-1/2" sports exhaust. WIll be interested in seeing if the figures change much along with the 3.23:1 LSD installed.
Just got my v35 350gt8 a week ago. runs 200kw at flywheel stock. Waiting on a few parts to turn up.
Used to have a na b18c type r powered crx with a few bits here and there running high 12s low 13s.
bout 180fwkw
Gonna try and beat that with the extra na displacement.
  • 1 month later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
